What do you call little? Can you feel it with the edge of your fingernail ?
You could try to polish It out with some 800 grit emery cloth and the follow that up with 1000 grit.
It's got a pretty nice gouge. I'm sure it will need to be turned.. The bearing has some wear on it.
I also got one cylinder with some wear. I think a good hone will fix it up. Now it's off to the cryo shop. Then we start putting it back together.
I wouldn't worry about that scratch to much. Polish or have someone polish off the burrs on the scratch and forget about it. It is in line with the oil journal and not across the bearing surface so it should not cause any excess wear or problems.
We will see what the machine shop can do. IM sure its nothing.terrible. we will get it right. Hoping to.drop off everything off for cryo within the.month
Great thread. Especialy since I just picked up a 12v cummins disassembled that had over $350 worth of machine work. I got head , block (bored) crank & cam ,pistons rods & valves.
all for 400. It was on flea bay. He started @ 850.
I wonder how many miles this motor would be good for with all the cryo'd this and Teflon coated that, balanced and blue printed, if it was kept at say 400 hp with good maintenance? I bet that thing would go a life time. Just posing a question.
What's to say it wont last at our goal of 1000hp?? We will overbuild the top end to spin at 5k. The rods are good to 1200hp. We will have ambient air intake temps thanks to an air to water intercooler and a big tank of ice water.
I think this engine will hold up great. IM hoping at least. Haha
I totally agree. I'm just curious what it would do if all the best parts and machining techniques were used, how long would it last. I know it will be fine at the power levels you're looking to achieve.
