Sponsored by: Real Truck
starter delay
Old Nov 28, 2010 | 06:59 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
starter delay
Sometimes on my o2 excursion when I turn the key and when it turns over there is a slight delay. She also eats batteries so I wonder if they are related. I have changed the alternator (More than once) so I don't think that's draining the batteries. Every winter as soon as it gets cold I have the problem. I don't know if it's the batteries being weak that causes the delay or the starter is draining the batteries.
Old Nov 28, 2010 | 09:34 AM
Rickx's Avatar
Rickx
My EX had that problem and it ended up being loose bolts holding the starter.
Old Nov 28, 2010 | 11:20 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I'll check that.
Old Nov 28, 2010 | 11:29 AM
Rongold's Avatar
Rongold
Slight delay of what ??? It clicks but doesn't crank for a second or it does nothing and then after a second or two it starts to crank. Either one of those scenarios is usually caused by a starter that is starting to go bad--Replace it before it leaves you stranded in the middle of nowhere !!!
RON
Old Nov 28, 2010 | 11:48 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
RON
I turn the key and there is a pause before the starter turns over. It only seems to do it when it's cold out or been sitting a few days.
Old Nov 28, 2010 | 01:28 PM
alwayschooseford's Avatar
alwayschooseford
I'd check the starter solenoid under the hood first
Old Nov 28, 2010 | 01:46 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It looks like the solenoid is on the starter. All the wires and bolts seem to be tight and clean.
Old Nov 28, 2010 | 04:09 PM
alwayschooseford
There is a solenoid on the starter and also one on the wall of the passenger side (at least on a single battery) of the engine compartment.
Old Nov 28, 2010 | 09:35 PM
BareBones's Avatar
BareBones
I'd clip a meter probe to the starter. If it gets juice the moment you turn the switch, then the problem is a mechanical delay in the starter, otherwise the problem is before the starter, like one of the relays/solenoids.
riclar
2009 - 2014 F150
Dec 28, 2015 02:32 PM
GaryMarq
Escape & Escape Hybrid
Dec 29, 2013 09:12 AM
egregg57
Jan 25, 2012 01:20 PM
FoSerius
1983 - 2012 Ranger & B-Series
Oct 19, 2011 11:16 PM
alconk
Jul 26, 2008 08:33 PM
