Rear Lighting Problem
Old Nov 24, 2010 | 09:57 PM
changoo's Avatar
changoo
For some reason my rear driver turn signal and brake light bulb will not work. I pulled the bulb that was not working out only to discover that the bulb was not burnt-out. I tried replacing it with a new one anyway, again no success. I pulled the fuses out and checked them as well; everything seems to be in working order. Where do I start next?
Old Nov 25, 2010 | 06:22 AM
MCDavis's Avatar
MCDavis
You need to check to see if they're getting voltage. Use a handheld meter to check for power. Could also be a bad connector into the taillight assembly.
Old Nov 25, 2010 | 07:14 AM
danorules's Avatar
danorules
if there is no power look under the truck near the spare tire. the wire harness for the rear lights split there. perhaps something grabbed it and pulled it apart, or the connection corroded and needs to be repaired
The Metal Panda
Dec 18, 2018 09:18 AM
FordMan9707
Feb 4, 2015 02:56 PM
Fastfwd
Aug 22, 2013 10:02 AM
sorensenj
1983 - 2012 Ranger & B-Series
Nov 10, 2008 08:12 AM
Goudey
1997 - 2003 F150
Jun 29, 2005 09:43 PM
