head gasket?
Old Nov 25, 2010 | 01:11 AM
johnboggs21's Avatar
johnboggs21
blown head gasket or cavitation
Old Nov 25, 2010 | 01:16 AM
91dirtydiesel's Avatar
91dirtydiesel
Ok thanks guys I'm going to try re torque the heads then we will see
ihateminimumwage's Avatar
ihateminimumwage
Coolant in the oil turns it a nasty dirty cream color, and the consistency of melted ice cream. If yours is still diesel black, you're doing alright.
Fill your radiator, pull the cap off and run the engine. Look in there and see what the coolant is doing (if it isn't blasting out of the rad filler like mine did from the blown gasket...) Look for bubbles.
EDIT: Read post #40 by Dave Sponaugle in this thread:
https://www.ford-trucks.com/forums/9...itation-3.html
Old Nov 25, 2010 | 01:22 AM
91dirtydiesel
ok ill try that.. that would solve one problem, but still the actual head gasket is leaking oil
Old Nov 25, 2010 | 01:24 AM
91dirtydiesel
My oil pressure was reading high, just a little high tho. Wich is not normal for my truck
Old Nov 25, 2010 | 01:28 AM
ihateminimumwage
Oil level is where it should be? More info the better.
Post back when you get a chance to test what everyone's recommended, we'll be able to help more when we all have a better idea what's going on in there.
Old Nov 25, 2010 | 01:32 AM
91dirtydiesel
Oil level was not terrible, yesterday was the first time it leaked, about the size of 4 quarters next to eachother. When it was running didn't notice any drips, only when it was off
Old Nov 25, 2010 | 01:49 AM
ihateminimumwage
Head gasket as far as oil goes would be my bet, test for the rest. Hopefully gasket, not cavitation.
Old Nov 25, 2010 | 01:56 AM
91dirtydiesel
Does the cold weather have anything to do with it? It was 9 degrees out last night, and also I usually run thicker oil. 10w40 with the lucas oil additive now just the 10w40, that have anything to do?
Old Nov 25, 2010 | 01:57 AM
ihateminimumwage
It wouldn't be the cause of the leak, but your oil pressure would read higher in the cold. The oil would stay thicker longer.
Old Nov 25, 2010 | 02:02 AM
91dirtydiesel
Alright well I'll give the coolant test a try tomaro and ill post the results
Old Nov 25, 2010 | 10:08 AM
Dodge/Cummins's Avatar
Dodge/Cummins
As far as head studs go; the 7.3L has much larger head bolts than the 6.9L.
I'm pretty sure head studs for a 7.3L are a lot more expensive than for the 6.9L.
Is your 10-40 oil rated for diesel engines? Won't make any difference as far as leaks go but diesels use specific oils, mostly 15-40. I'm not sure if the Lucas addative takes care of it or not. As stated 10-30 diesel oil is OK for extreme cold.
Your oil "pressure" gauge in the dash is basically an idiot light. If you have 7 PSI it shows pressure, not a specific high or low state. You may have an aftermarket gauge for all I know however.
Old Nov 25, 2010 | 11:45 AM
  #28
91dirtydiesel
Filled up the coolant, ran it and it ran fine no smoke. Still leaking oil and it appears there is a small amount of oil in the rad. The top layer is shinny like oil on water. No bubbles in rad, and nothing gushing out when it was open. The oil is still "diesel black"
Old Nov 25, 2010 | 12:58 PM
  #29
91dirtydiesel
It looks like there is coolant in my tranny.. this possible?
Old Nov 25, 2010 | 01:13 PM
  #30
Dodge/Cummins
Yeah, if it's an automatic the radiator and the trans. cooler are the same unit, two compartments.
