Steering column slop..
Old Nov 24, 2010 | 04:08 PM
Krisx125's Avatar
Krisx125
k guys im almost done with my tranny sawp. And while doing it i had my column from my Manual truck and my auto truck on the bench. When you lock the column the manual one doesnt move. And my auto column turns about 2 inches each way. My auto one has always been veryy sloppy. And when i drove the truck it would go clunk clunk clunk. So when i just went to put my column back in i noticed the bar that goes the the steering box has a ton of play and makes the clunk noise. I know i can fix that with a new gear box. However what do i do about my steering column? How do you make it tighter??
Old Nov 24, 2010 | 04:31 PM
Action4478's Avatar
Action4478
If you are talking about the intermediate shaft , it has a plastic bushing in it that can wear out & cause the noise ..
On mine ,I just welded the shafts together, they are designed to slide one inside the other...
Old Nov 24, 2010 | 04:43 PM
Krisx125's Avatar
Krisx125
Alrighty ill weld mine also. But what would make the wheel slop? Even when its out of the truck?
Old Nov 24, 2010 | 04:57 PM
Action4478's Avatar
Action4478
That has to be something else ...Are they both tilt wheels ?..
Old Nov 24, 2010 | 05:03 PM
Krisx125's Avatar
Krisx125
yea both tilt wheels. I just went back into the shop and looked, right where the shaft goes into the gear box the shaft is sooo loose. Like ready to break off loose haha...So time to get a gear box.
Old Nov 25, 2010 | 10:08 AM
Talyn's Avatar
Talyn
Thanks Rick. I"ll have to check that.
Higbean
Feb 10, 2013 10:23 PM
52' fordnut
Dec 10, 2012 07:51 PM
willys_gasser
Jul 29, 2008 06:34 AM
mirrormaker
Aug 21, 2003 12:06 PM
