Truck wont start...
Truck wont start...
I took the panel off that sits below the windshield wipers and truck was running fine I also had to remove the weather guard that keeps water from dropping into the back of the engine bay. It got rained on and still ran fine but just before I parked it for the night it stalled and would not turn back on. Now when I start to turn it on it just turns over strong but wont ignite... Also just before that the antilock brake light went off... could that have something to do with it?
could something in the back of engine bay have gotten wet, that shouldnt have?
its a '87 EFI regular cab.
thx
thx
I recently took the bed off to paint it, but if i smashed a line or anything puting it back on it woldnt have run for the 20 miles that it did.
the engine has 98k on it.
I'll have to check for the fuel pumps when starting it.
I live in so cal and recently drove it up to san francisco and back with no odd behavior runs like a champ.
Sure it will. It just won't fire.
the distributor is not wet, its fine, I even hit it with a blow dryer on high heat to get rid of any water. If i was to buy some starter fluid where would i spray it, the intake manifold? is this a good idea? The gas tanks were really really low right before this happened so im pretty sure its gunna be a clogged filter or line... if thats the case do you think the starter fluic will fire it up and push the material through?
kidkyle21
07-04-2013 10:25 PM
EL_Musico
13
09-18-2011 05:42 PM
Fiddy 6
Electrical Systems/Wiring
05-01-2009 06:57 PM
IZZYAZ
04-29-2009 08:17 AM
