Short block?
Old Nov 25, 2010 | 08:02 PM
96ford250's Avatar
96ford250
Short block?
Ive been planning a rebuild on my motor for a while now and ive been wondering since there is so many miles on my truck it is highly unlikely that i will be able to just rehone the cylinders and rering the pistons so would it be cheaper to send the block off to get the machine work done for a rebuild or just buy a short block does anyone have any advice on this my truck has 215k miles on it. Thanks Chuck
Old Nov 25, 2010 | 09:06 PM
L. Ward's Avatar
L. Ward
That depends on how comfortable you are with you abilities to assemble a motor. If you are comfortable, send the block out for machine work, get a kit and do the assembly yourself. If you aren't that comfortable doing the assembly, look at having the shop do it for you. A good shop will be able to build what you want and should be reasonably competitive on the price. Don't forget the heads too, at 215k, they are going to be due for some work too.
Old Nov 25, 2010 | 09:09 PM
96ford250's Avatar
96ford250
im comfortable i just want to kno whats cheaper there trying to charge 1000 for just the block to get done thats not even the heads
Old Nov 25, 2010 | 09:16 PM
L. Ward's Avatar
L. Ward
If thats just the machine work, that sounds awful high. If thats a complete short block, ready to bolt the heads back on, thats a bit more reasonable. Jasper lists their 5.8 at <table><tbody><tr><td nowrap="nowrap" align="right">Price: </td><td nowrap="nowrap" align="right">2285.00</td><td>
</td></tr><tr><td nowrap="nowrap" align="right">Core Charge: </td><td nowrap="nowrap" align="right">350.00</td><td>
</td></tr><tr><td nowrap="nowrap" align="right">Skid Charge: </td><td nowrap="nowrap" align="right">15.00</td><td>
</td></tr><input name="sMLPS" value="" type="hidden"><tr><td nowrap="nowrap" align="right">Kit Price: </td><td nowrap="nowrap" align="right">347.00</td></tr></tbody></table>
Old Nov 26, 2010 | 01:37 AM
96ford250's Avatar
96ford250
2285 for a short block or a long block? ive found these guys and they seem pretty reason able but there a little bit of a drive
Pilot Engines, Inc. - Home
Old Nov 26, 2010 | 07:00 AM
L. Ward's Avatar
L. Ward
That would be a Jasper ReMan long block, ready to throw your intake, exhaust and accessories on and drop right back in the hole. Back in Ohio, we installed a fair number of them and they were always dependable and backed their product up.
Looking at the link you posted,
degrease disassembled engine.....50.00oven clean and shot peen bare block...75.00
Deck block (true up) 25.00
Bore & Hone cylinders.....80.00 (10.00x8)
Install cam bearings.....20.00
Install freeze plugs (sides) 10.00
Align hone block.....110.00
Crankshaft Clean/Shot Peen/Turn & Polish 95.00
So you are looking at approx $465 on the bottom end alone, add another $325-400 for a rebuild kit (cast piston vs. hypereutectic)from someplace like Summit, and you've got $790 to $865 in the bottom end, add in another 200-300 to have the heads done and 70 or so for a good timing set, and you are looking at $1135-1235+ for the rebuild if you do the disassembly/reassembly yourself. Thats just a basic rebuild, no cam or extra goodies you may decide to go with, but its still $1300 less than the motor from Jasper (2300+350 install kit)
Old Nov 26, 2010 | 09:26 AM
96ford250's Avatar
96ford250
Yea but they sell long blocks for 1105 + tax so thats y im wondering what to do i have a gt40 heads i want to put on too
Old Nov 26, 2010 | 09:50 AM
hav24wheel's Avatar
hav24wheel
$1200 for a complete rebuild on my 351W, that included upgraded cam, valvesprings, retainers, locks, double roller chain, .030 over pistons, rings, bearings, oilpump, gaskets, frost plugs, machine work on the block, heads, and crank.
Old Nov 26, 2010 | 09:54 AM
96ford250's Avatar
96ford250
How much did you pay for the machine work if u dont mind me askin
Old Nov 26, 2010 | 10:02 AM
hav24wheel's Avatar
hav24wheel
Heads, $180, included assembly, valve job, and guide knurl.
Block, $230, checked aline bore, bore .030 over. Install cam bearings, and install pistons on rods.
I did rest of assembly, and got my rebuild kit from Northern auto parts.
A local machine shop did the machine work.
Old Nov 26, 2010 | 10:05 AM
96ford250's Avatar
96ford250
wow thats alot better then what they want to charge here
Old Nov 26, 2010 | 10:11 AM
hav24wheel's Avatar
hav24wheel
If the heads and block don't need a lot of work its cheaper. Take a lot of measurements and know what has to be done. If the motor didn't get hot, more than likely it won't need to be decked, or aline bored.
Yes my prices where cheaper than most, but I was also informed his prices would be going up soon.
Old Nov 26, 2010 | 10:15 AM
hav24wheel's Avatar
hav24wheel
O, and do everything you possibly can before you take it to them, like total disassemble, pop out frost plugs, and clean it too.
Old Nov 26, 2010 | 10:17 AM
96ford250's Avatar
96ford250
my truck has been owned by older guys the whole time by a cop and a fireman both in their 30s/40s so they kept it in good shape and to have 214k on it and it still have the origional clutch in it i know they didnt hot rod it and took care of it
Old Nov 26, 2010 | 10:21 AM
96ford250's Avatar
96ford250
I plan on it and ive got access to a parts washer so i can clean everything in there but the block
