Any one know if......
Old Mar 16, 2012 | 09:06 AM
  #31
TexasGuy001's Avatar
TexasGuy001
That looks satisfactory to me too.
Old Mar 16, 2012 | 07:03 PM
  #32
SideWinder4.9l's Avatar
SideWinder4.9l
I know this isn't entirely on topic but here goes...
I have a 1992 F150, and bypassed the SMOG pump...
I've been using a 80.5" belt, with NO issues...
Only thing close to an issue, was my belt tensioner was FUBAR'd....Cut the 2 ribs of the backside of the belt (Towards the engine)
Replaced the Tensioner setup and it's fine....
Old Oct 7, 2012 | 09:18 AM
  #33
Kevin Roth's Avatar
Kevin Roth
[QUOTE=White Max;11577213]If you alter the belt routing a bit, the low mount tensioner setup will work satisfactorily without the need for an idler in place of the smog pump. The routing of the belt is as follows: from the crank pulley around the water pump pulley, to the ps pump, to the ac compressor, under the tensioner (not the idler), to the alternator, then back to the crank pulley. You won't use the upper idler pulley in this configuration. On a 5.0L, this routing will require a 93.7" or 94.0" belt (93.7" is best, but takes a little effort to get into place).
More info: https://www.ford-trucks.com/forums/1...-question.html
White Max has the solution. See the pictures ealier in this thread. This worked for me on a '96 E-350 w/ 5.8 351W. Tensioner mounted on the side. Belt length (after some experimentation) turned out to be 97.5". Some users might have "belt flap" issues at high rpm. This truck is a stock, low rpm hauler for me. I'm 99% sure the eliminator pulley mentioned at the beginning (page 1) of this thread will work on a 5.8 also. I'll raise a cup to White Max!
Old Jul 2, 2014 | 05:09 PM
  #34
carlislefordf250's Avatar
carlislefordf250
[QUOTE=Kevin Roth;12347716]
I have done exactly this on my truck. 94 f250 with 5.8. Ran the route exactly like you guys have said without the smog pump or replacement bracket and pulley, even not using the idler pulley, just like in your pictures. Using 97.5 inch belt.(tried a 97, wouldn't fit) Now, my problem is, my truck squeals real loud when i start it up then it goes away. I started a thread asking how to resolve this. Most guys are saying its the brand of belt i'm using, valuelast. Is this a problem u had? I have noticed that with this set up that the tensioner almost goes all the way back down to where it would sit without a belt and it bounces slightly when the engine is running. Is this normal? but like i said, i tried a 97 inch belt and it wouldn't fit.
Old Jul 2, 2014 | 06:46 PM
  #35
Shadow944795's Avatar
Shadow944795
I never bothered with the silly eliminator brackets on my truck. I just bought a shorter belt and so far I've never had it jump off, squeal or have an issue with the belt flapping to much but that's just me.
Old Apr 2, 2018 | 09:37 PM
  #36
Kaden Junker's Avatar
Kaden Junker
Originally Posted by strokin'_tatsch
What is wrong with running the belt without the pump or eliminator bracket? I have an eliminator bracket, but I couldn't see any way to get it to fit. It bolted up under the alternator, but there was no other place to bolt it up so I just got a belt that fits without the bracket. It seems like it'll work just fine, just thought I'd ask.
What size belt did you end up running.
Old Aug 9, 2018 | 10:29 AM
  #37
CamoF-250's Avatar
CamoF-250
Did removing this system cause check engine light 311?
Old Dec 16, 2019 | 11:34 PM
  #38
TobyB's Avatar
TobyB
Originally Posted by BearFootCustom
Thank you, its been driving me nuts
So, a sailor walks into a bar with a steering wheel shoved into his pants...
t
Big Dick Dubloon
Apr 15, 2017 07:24 PM
Driving Line
Aug 19, 2016 06:28 PM
Tim Hodgson
Feb 12, 2015 09:56 AM
TBird Larry
Aug 2, 2014 08:46 AM
Stephen67
Jun 12, 2014 02:54 PM
