Idler pulley bracket
Old Nov 22, 2010 | 04:33 PM
romod's Avatar
romod
Okay guys I'm finally tearing into that timing belt,first problem I ran into is how to get that idler pulley bracket out of the way to get off the belt cover and out of the way.I already took off three long bolts that I can see and it still won't budge,do I have to take out the power steering pump also? If so how does that pulley come off because the mounting bolts back right into the pulley before coming out.Its a 2000 2.5 Lt. engine
Old Nov 22, 2010 | 05:12 PM
03 Maz B23's Avatar
03 Maz B23
The power steering pump gets removed according the instructions.
| Repair Guides | Engine Mechanical Components | Timing Belt | AutoZone.com
Old Nov 22, 2010 | 05:49 PM
romod's Avatar
romod
Alot of good info there but doesn't explain how to remove that compressor bracket, its the only thing in the way of getting that cover off,the more I research the power steering thing it looks like its a special tool deal,,,wonder if backing off the mounting bolts evenly would do the trick without damaging the pulley?
Old Nov 22, 2010 | 11:22 PM
g_k50's Avatar
g_k50
Remove three bolts and one stud to remove AC Bracket and PS pump attached. Position out of the way.
Old Nov 23, 2010 | 01:32 AM
romod's Avatar
romod
Pretty sure I got the three bolts but where is that stud,is it hidden somewhere behind the pump?
Old Nov 23, 2010 | 04:38 PM
romod's Avatar
romod
Found the stud it is behind the pump and had to get a 13 mill wrench to loosen it,bracket is now loose finally.Now I'm trying to figure out the tensioner,the spring bolt is loose but not all the way out and so is the adjusting bolt,how do i move it it now
hypnotist
Mar 20, 2016 01:32 PM
texansport
2004 - 2008 F150
Sep 5, 2015 08:42 PM
SaturnSky11
May 29, 2014 07:32 PM
Kingkoopa
Nov 8, 2013 03:49 PM
mikeclinch
6.4L Power Stroke Diesel
Sep 28, 2012 04:29 PM
