E4OD Trans questions..
Old Nov 22, 2010 | 12:36 AM
ManicMike's Avatar
ManicMike
Originally Posted by oreocreaming
e4od 4x4 out of a 97 psd
How much? Your actually kinda far. So shipping would suck. Local to me has one for sale a decent price.
oreocreaming's Avatar
oreocreaming
and ive got the t/c and the mid driveline so nothing but the MLPS, Solenoid body, and torque converter is needed
Old Nov 22, 2010 | 12:38 AM
oreocreaming
no prices in forum so i sent you a pm
Old Nov 22, 2010 | 12:52 AM
ManicMike's Avatar
ManicMike
Oreo brought up a interesting point. I'll be able to reuse my transfer case (1356, I think), right? That thing is practicably brand new.
Old Nov 22, 2010 | 01:00 AM
David85's Avatar
David85
Everything I'm finding indicates the 1356 TC was used right up to the end of the bodystyle in 97 so you should be fine.
Old Nov 22, 2010 | 01:03 AM
oreocreaming
you would be correct sir
Old Nov 22, 2010 | 11:05 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
a few recommendations.
if you do find a '95-97 trans it already has the high volume pump.
if you find an older E40D,hit ebay and search for the high volume trans pump.also consider the viton front pump seal.
consider a temp gauge,external filter and cooler,and a shift kit.
now is the perfect time for these little basics.
Old Nov 22, 2010 | 02:40 PM
ManicMike's Avatar
ManicMike
Nah, it's a 97 so has the better pump. Being a reman from Ford, I think it'd have the better parts in it. I have a temp gauge and cooler already. I had a inline filter, it sucked and caused hi temps in the old trans. I'll just be using the normal pan filter. I might add a shift kit later on down the road. For now, I want the truck back on the road before winter hits.
Actually, I SHOULD be going to pick the trans up tonight.
7DF250
Feb 26, 2015 07:22 PM
jlarr
Jan 4, 2015 09:47 PM
boxdin
May 2, 2014 08:08 AM
94flaresideon20s
Nov 7, 2012 12:18 PM
Robbgt
Feb 12, 2005 06:19 AM
