Sponsored by: Real Truck
OBD II Code Reader/ EOBD Scanner Question??
Old Nov 21, 2010 | 07:05 PM
tcr1016's Avatar
tcr1016
I am new to gas engines, drove most older diesels. But my question is does a OBD II Code Reader/ EOBD Scanner tell me if there is any problems on a 2004-2009 Ford V8?? Is the Harbor Freight Scanner CAN OBD II Code Reader/ EOBD Scanner - Diagnostics - Automotive & Motorcycle
Will the OBD II Code Reader/ EOBD Scanner tell me if the tranny is goin out, the pistons are misfiring, the head gasket warn, coolant or any leaks like oil, or any other engine problems???
Old Nov 21, 2010 | 07:30 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, no, maybe and sometimes. It depends on what code is issued and how it is interpreted. It isn't all cut and dry.
A code reader will show you an error. It might say you have a misfire in 2 adjacent cylinders, but will not tell you a head gasket failed. It isn't cut and dry. You may see a P0306 code (Cylinder 6 Misfire Detected) but now what caused it? COP? Spark plug? Boot? Vacuum leak?
The code reader you linked might be OK, but I do not see anything in the specifications about reading pending codes. With these engines it is important to read the pending codes. It takes many many misfires to light the CEL and issue an error code, but the misfires will be on pending codes. (Yes, this is very common).
Old Nov 21, 2010 | 08:22 PM
tcr1016's Avatar
tcr1016
Thanks for the fast responce REDFORD. Will is read a Vacuum leak?? The reason I ask is the auto inspectors charge $200 + and I see this is all they use. I just want to know if the engine has any trouble before I buy.
Old Nov 21, 2010 | 08:32 PM
redford's Avatar
redford
A vacuum leak can be any one of several error codes, depending on where it is and the severity.
$200 seems very steep for a vehicle inspection. Call a few repair shops and see what they charge for a pre-sale inspection.
TomFL
Mar 22, 2014 04:42 PM
Jaime74656
17
Dec 26, 2011 08:09 AM
Coastie6
Sep 7, 2011 07:15 PM
dave03835
May 16, 2010 11:20 AM
98SurplusExpy
Apr 9, 2010 04:01 PM
