Leaking HPx
Old Nov 21, 2010 | 01:54 PM
bama29fan's Avatar
bama29fan
Leaking HPx
just installed the HPx and its leaking on the passenger side. it feels pretty darn tight and im a little worried about trying to tighten anymore. looks like its coming from the bottom fitting that goes in to the head. how much can you tighten those? how risky is it or easy is it to strip them?
in order to tighten the bottom one is it necessary to loosen the top one a little but?
Old Nov 21, 2010 | 01:57 PM
woodnthings's Avatar
woodnthings
The plugs in the head are ORB, and shouldn't need torqued to much. What kind of HPx is it? Mine is a SS tube that uses flareless fittings so If you over torque the line it can get damaged.
Yes, loosen the line first.
Old Nov 21, 2010 | 02:21 PM
bama29fan's Avatar
bama29fan
its the SS one from RiffRaff
Old Nov 21, 2010 | 03:20 PM
duck fan's Avatar
duck fan
Because racetruck
Shawn, double check the O-ring and make sure it's not kinked. You want to tighten it just enough to seat the o-ring without destroying it. Also make sure you clean the area real well so that you can spot any leaks right away.
Old Nov 21, 2010 | 03:39 PM
bama29fan's Avatar
bama29fan
So it doesn't have to be super tight to seal off correctly...thanks guys I'll redo it and see if I have better luck
Old Nov 21, 2010 | 05:25 PM
bama29fan's Avatar
bama29fan
Well the top fitting took about a quarter turn and stopped leaking. Thanks for your help
Old Nov 21, 2010 | 08:31 PM
Robert6401's Avatar
Robert6401
Shawn, good job getting it figured out. Now y'all gonna take care of Cam Newton this week so the tiggers have less to play for when we meet them in Atlanta next week?
graphite675
2004 - 2008 F150
Mar 26, 2021 08:10 PM
Km1210
82
Apr 27, 2016 02:52 PM
carguy3j
26
Jul 31, 2015 03:48 PM
JonathanN
Jan 25, 2012 09:59 AM
BuckHammer
43
Oct 5, 2011 01:49 PM
