Sponsored by: Auxito
Alternator Amp rating
Old Nov 18, 2010 | 03:41 PM
randy6800's Avatar
randy6800
Exclamation Alternator Amp rating
My truck is a 2000 F150 S/C with the off road package and towing package and the 5.4 w/ a/t. How do i tell what amp alternator is on my truck, I was going to order one online with Rockauto, do I have to remove in order to see it stamped someplace? I was hoping not to remove it until I have the new unit, I was looking at the Motorcraft reman, not sure if Advance Auto has better units than in the past. Thanks for the help
Old Nov 18, 2010 | 06:12 PM
steve(ill)'s Avatar
steve(ill)
At one time the 130 amp had 7 rib belts and the 100 amp had 6 rib belts. Not sure that is a guarantee... If you have a 5.4 with off road package and towing, i would assume you had the 130 amp. Either will worth, they both fit the hole.. pulleys will interchange. i bought one off e-bay that was a takeoff from a guy that built ambulances out of F250s
Old Nov 18, 2010 | 07:01 PM
randy6800's Avatar
randy6800
It does have the 6 grove pulley, I may just pull it off and pick up one at Advance Auto. I have also seen new Motorcraft take offs on ebay in the past where they remove the stock alternator to build wreckers, fire and rescue trucks etc. I will do a search.
Old Nov 18, 2010 | 10:19 PM
n3up's Avatar
n3up
I have a 97 with tow package.
The tow package had 130A in 97.....
coolfeet
Mar 6, 2018 08:07 PM
SoCalAngler
2004 - 2008 F150
Jan 15, 2017 04:13 PM
Bigdon68
May 2, 2016 08:40 PM
kincfu
Mar 9, 2016 11:20 AM
lakewood
Jul 9, 2012 01:24 AM
