Higher amp output alternator for 2000 E150
Old Mar 7, 2016 | 08:50 PM
kincfu's Avatar
kincfu
Hello,
I plan to put in a 300 watt audio system in my van. Do I need a higher output alternator?
For my Jeep Grand Cherokee, I ordered a Durango 130 amp alternator to replace the stock 90 amp one.
Don't know if any other Ford alternator with higher amp output will fit this van.
Any suggestion will be greatly appreciated.
Kin
Old Mar 9, 2016 | 08:38 AM
jimandnena's Avatar
jimandnena
Oreillys lists a 130 amp reman but it depends on your engine size. Need more data. jim
Old Mar 9, 2016 | 09:32 AM
jeffreyclay's Avatar
jeffreyclay
Your stock alternator should be sufficient. A 300 watt load@ 12v only draws 25 amps. Music, not being a steady demand, would average less than 25 amp.
Old Mar 9, 2016 | 10:43 AM
Tedster9's Avatar
Tedster9
What size fuse do you suppose the "300 watt" amplifier has protecting it? Betcha it ain't even close to a 25 amp fuse.
Old Mar 9, 2016 | 11:11 AM
tx2sturgis's Avatar
tx2sturgis
Thumbs up parts
If you like to crank it up loud and are using a large subwoofer, I would spend a few dollars for an audio thumper capacitor and wiring kit, which will help smooth out the surges on the stock electrical system, but your stock 90-120 amp (I assume) alternator should be ok.
Old Mar 9, 2016 | 11:20 AM
tx2sturgis's Avatar
tx2sturgis
Thumbs up ratings
Thats a good point, some of these amps are rated at say, 300 watts PEAK.
Which means the actual music power (RMS) is much less.
kyle j
Jan 28, 2013 09:51 PM
v_dub_1988
1997 - 2003 F150
Dec 29, 2008 07:44 AM
Mazda_man
1983 - 2012 Ranger & B-Series
Nov 8, 2004 10:27 PM
meck1
Jun 24, 2003 07:54 PM
