hydroboost questions
Old Oct 25, 2011 | 12:46 PM
  #136
F-250 restorer's Avatar
F-250 restorer
Originally Posted by 74sb4x4
So I have been doing a lot of reading and can someone tell me what all I would need to convert to hydroboost . Year? Make? Model? And other parts I can but from a a parts store that would save time. I kinda new and am just getting confusing I am also looking to swap to front disc breaks and would like to know what I can get it from straight bold on conversion. Thanks so much
All the info you need can be had by doing a search in this forum and writing down what other guys have used. There is no one answer. Every guy has done it differently. You just have to decide what is best for you and go for it. There is usually welding involved, fabrication, and making of or buying lines from p/s pump to unit.
Good luck.
Old Oct 25, 2011 | 01:32 PM
  #137
dethomson's Avatar
dethomson
You could always ask the junk yard to pull the power steering pump, hoses, hydroboost, etc for you. There's also a good chance someone is parting out a truck in your area that has the hydroboost in it and will run you a good deal. That's what I did...found a guy parting out an F450. I did have to get the F250 master cylinder though. If you do go used, make sure the hydroboost unit does not have any leaks!
FORDF250HDXLT
107
Mar 19, 2020 10:29 AM
mike1202002
Nov 1, 2016 11:56 PM
Powerboss1967
Jul 30, 2015 10:11 PM
Macrobb
Jul 13, 2015 11:18 PM
