Hydroboost gurus
Old Apr 13, 2016 | 05:14 PM
mike1202002's Avatar
mike1202002
Hydroboost gurus
So I am considering going hydroboosts on my rebuild of 1978 f250. But I was wondering if anyone would happen to know the difference between the super duty hydroboost units that are recommended. And a1996 cobra Hydroboost unit?
The only reason I ask is I have the cobra unit laying around from a mustang part out
Old Apr 13, 2016 | 10:15 PM
650's Avatar
650
Im not an expert on these things but from my understanding the hydroboost units are the same for the most part except for the pedal rods and some early Ford units have oddball psi in/out fittings. Also some have different bolt patterns for the master cylinder. If you have 1 laying around, try to bolt it up and see how close it is.
I used a booster off a 2008 F.350 for my highboy. The pedal bolted right up to the rod. The master cylinder also bolted right on. Then I just build an adapter for onto the firewall that was about 2" thick. Hydratechs' website is a great resource to find your line fittings.
Old May 2, 2016 | 10:46 AM
dannyboy_86's Avatar
dannyboy_86
Sorry to Hijack your thread a little bit here, but had a question on late 70's Lincoln hydroboost unit. I got one out of a u pullet yard awhile back and the master cylinder's ports are on the passenger side of the vehicle, tried the master off my 77 f250 but the bore is too big to fit, anyone know of a master cylinder that fits that hydroboost unit with ports exiting toward the driver side? I will be upgrading to rear discs in the rear as well before it is back on the road.
Old May 2, 2016 | 11:48 PM
teds74ford's Avatar
teds74ford
I used a 70s f350 MC. I had to slightly enlarge the mount holes to get it to bolt to my hydroboost.
Old May 3, 2016 | 10:18 AM
dannyboy_86
Is there a particular year F350 Master cylinder to use, based on rockauto some of the ones for the F250 Overlap some of the ones for F350 depending on year. Would the F350 one run 4 wheel disc just fine?
Old May 3, 2016 | 10:57 AM
650's Avatar
650
Maybe get a Superduty master cylinder. I believe they exit the driver side and will have a larger fluid reservoir for your disc brakes when you upgrade.
Old May 3, 2016 | 11:14 AM
hasteranger's Avatar
hasteranger
Get one from a junkyard, then you can get the lines with it. Makes getting fittings easier.
Old May 3, 2016 | 02:00 PM
dannyboy_86
I just checked the u-pullit yard and they don't have any super duties at all.
Old May 3, 2016 | 02:34 PM
hasteranger
Check lkq, car-part.com, or junkyard dog or use a Craigslist searcher like search tempest to find someone parting one out.
Old May 3, 2016 | 04:49 PM
dannyboy_86
That brings me back to my original question, looking at the ones for an 08 super duty, that's exactly what I'm looking for, but will it fit in the 70's Lincoln Hydroboost? Anybody know what the outside diameter of the super duty master cylinder bore is?
Old Nov 1, 2016 | 11:56 PM
highoctane74's Avatar
highoctane74
Ever get this figured out?
nilzlofgren
Sep 18, 2016 06:52 AM
Uni Moe
Oct 7, 2014 02:55 PM
Uni Moe
Oct 7, 2014 12:41 PM
mgargiullo
Apr 13, 2014 09:19 AM
chenders
Sep 13, 2000 06:14 PM
