Fuse Box
Old Jan 27, 2013 | 11:28 PM
bucks77ford's Avatar
bucks77ford
My 75 is the same as the smaller one. Amazing there is only 5 total circuits, but then again there wasn't much really to power.
Old May 16, 2013 | 09:19 PM
rogue40's Avatar
rogue40
My 77 F250 4x4, manual transmission, has the same fuse box as the one in Steponit's post except the #9 spot is blank (just the space but no terminals).
I have no power to my blinkers.
Tested the turn signal switch as per the Ford shop manual and it checked out good.
4-ways work fine.
Back up lights quit working.
Have power in the right wires up and down the steering column.
Have no power to the turn signal flasher in either direction but the flasher checks out ok.
I haven't been able to determine which fuse space is used for the turn signal.
Anyone know why mine is different and ideas of where to look?
Old May 17, 2013 | 11:31 AM
rogue40's Avatar
rogue40
4-ways work fine.
bump
(they say I need ten characters)
Old May 17, 2013 | 03:39 PM
OrangeBeast's Avatar
OrangeBeast
Turn signals are number 11 B/U and emergency flashers are number 8 EMERG; could be why you have flashers and not turn signals. Give me a little time and I will post a pic from the service manual and from my owner's manual. I need to scan my owner's manual to show you the fuse information. Once I have it scanned I will post it for you. I checked my truck which is also a 77 F250 4x4 and it matched what my documentation shows...numbers 6 and 9 are blank.
Old May 17, 2013 | 06:17 PM
OrangeBeast
As promised, here are the diagrams.
Old May 18, 2013 | 08:23 AM
rogue40's Avatar
rogue40
Thank you OrangeBeast. That is exactly what I was looking for.
Old Aug 9, 2013 | 11:38 AM
77Greene's Avatar
77Greene
Ok, I'm ready for a bit of knowledge if anyone can help.
My fusebox looks just like the one from OrangeBeast....however there is a wire jammed into fuse #11.
does anyone know what it could be?
Mobile Upload - Imgur
Old Aug 9, 2013 | 11:40 AM
77Greene's Avatar
77Greene
just seeing if I can use this link to show in detail:
<a href="http://imgur.com/o6xJAlq" title="Mobile Upload"><img src="https://i.imgur.com/o6xJAlq.jpg" title="Hosted by imgur.com" alt="Mobile Upload"/></a>
Old Aug 9, 2013 | 11:41 AM
77Greene's Avatar
77Greene
Sorry for the size....I'm not sure what I'm doing ....yet
Old Aug 9, 2013 | 12:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That's something that's been added by a previous owner. You'll need to follow the circuit to find out what its for.
If it dead ends, remove it.
Old Aug 9, 2013 | 12:36 PM
77Greene's Avatar
77Greene
Thanks Mike. I'll check it out. Seems like a bold/risky mod. Can't wait to see what else is rigged up in here!
Old Aug 9, 2013 | 12:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No problem. I always say, one of the WORST things that can happen to our trucks is a previous owner.
Old Aug 13, 2013 | 07:18 AM
  #28
ford_pickup's Avatar
ford_pickup
I would bet money that is there for a new style radio/cd player
Old Aug 13, 2013 | 07:35 AM
  #29
J ballan's Avatar
J ballan
Yep me to. New style CD player.
Old Aug 13, 2013 | 07:55 AM
  #30
77Greene's Avatar
77Greene
Ok. Yep, that was it. after I removed that wire the radio stopped lighting up. The fuse was completely broken anyway. I replaced a handful of the fuses over the weekend. The guys at the 2 Advanced Auto Parts stores that I visited were pretty much useless.
I have ordered a replacement radio and speakers to install so we'll see how this all goes. In the near future I'll go ahead and replace the whole wiring harness. I'm pretty confident that I've only scratched the surface on the electrical hiccups.
Here's a pic of the new shiny fuses...(hope this one is a more reasonable size)
<a href="http://imgur.com/XlAGHhU" title="Mobile Upload"><img src="https://i.imgur.com/XlAGHhUl.jpg" title="Hosted by imgur.com" alt="Mobile Upload"/></a>
whalerron
Sep 19, 2019 05:40 AM
DieselCamper
Aug 18, 2016 05:34 PM
mtdorf
Electrical Systems/Wiring
Oct 16, 2012 06:55 PM
piecrazy4
Mar 22, 2011 08:42 PM
tx64f100tx
Feb 20, 2006 05:10 AM
