59 F100 fuse box
Old 10-14-2012, 11:01 PM
mtdorf
mtdorf is offline
mtdorf is starting off with a positive reputation.
59 F100 fuse box
Does a 59 F100 have a fuse box? If so, where is it located? i can't seem to find it.
Thanks for your time and responses.
WD
Old 10-15-2012, 06:30 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I know my 53 didn't. Here's a 59 car diagram, and it doesn't either. It has fuses sprinkled here and there throughout the harness.
http://www.oldcarmanualproject.com/t...re5765-199.jpg
Old 10-16-2012, 09:05 AM
mtdorf
mtdorf is offline
Thanks the diagram helped alot, didn't know about that website...great info. I have printed it and will begin the wonderful job of tracking down the wiring issue. Have you put in a new harness in your 53 to include a fuse box? If so, how difficult is it to get everything rewired?
Thanks
Old 10-16-2012, 06:55 PM
Franklin2's Avatar
Franklin2
I re-wired my 53 myself(made my own harness). I went along the same theme as the original harness, which had only 2 main circuit breakers. I didn't do a lot of electrical add-ons, I just changed it to 12 volts, added turnsignals, and a more modern engine and tranny, but it still had points ignition. I didn't feel the need to add a fuse box, but if I did, I think I would buy one of those small ones you can get in the parts stores on the shelf that holds about 5 or 6 fuses. Unless you are going to add a lot of modern power accessories, that should be enough. If it's not, you can add another one to get 10 or 12 fuses.
If you do not feel like making your own harness, they have them with the fuse box included, but you will still have to decide what switches you are going to use, what steering column, what charging system, what ignition system, and adapt these harnesses to work. That's why I just built my own.
Jsek
02-22-2017 04:23 PM
jamhh
09-17-2016 01:59 PM
Curford
07-18-2016 11:41 AM
slayercr23
10-15-2009 08:00 PM
tx64f100tx
02-20-2006 05:10 AM
Quick Reply: 59 F100 fuse box
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
