2016 F250 Superduty - Adding a circuit with "Add a fuse"
I just stumbled upon the Add-a-fuse units which replace a fuse in the fusebox with 2 fuses and a pigtail for adding another circuit. The 2016 Superduty fuse box behind the front passenger kick panel uses low-profile ATM fuses. Has anyone found a "add-a-fuse" which will work in that fusebox? Because the fuses are inset below the top of the fuse panel, I have not been able to find an "Add a fuse" which will fit the fusebox. Thanks.
Mike, thanks. I saw those adapters but because the tops of the fuses are inset into the fusebox, that unit will not plug in all of the way into the box. It would need a longer insert to counter the depth of the box. That unit is designed for a box where the tops of the fuses are flush with the top of the box.
I need a source to power the lights in my cap and I was hoping to do this without splicing into one of the power point pigtails. On my last truck, I soldered splice into the cigarette light pigtail and it did exactly what I needed. My 2016 doesn't have the upfitter switches but I wasn't aware of the available wires near the C210 connector. I will look for those. I need 12V all of the time so that the cap light will work without a key in the ignition. Thanks.
There should be two customer access wires that are taped to harness near connector C210 in the passenger kick panel area. One is a fused connection that is hot in run/acc, it is White with Blue stripe and the other appears to be hot all the time, it is White with Violet stripe.
I'm going to look into these pigtails near C210. I'm sure they'll come in handy in the future. Anyone have any pics?
-J
There is a group of about a dozen pigtails on the driver's side near the kick panel and they seem to be there for a PTO unit which I don't have. One is White with a Blue stripe and it is labelled Run/ACC. Another is White with a violet stripe but it is labelled Parking BK. Are these the ones to which you are referring? There is a white with Orange stripe that seems to pass through the firewall to the engine compartment. I was planning on using that one carry the 12 V from under the dash to the outside.
The 4 pass through wires are these colors
Brown w/White stripe
White (no stripe)
White w/Orange stripe
Grey w/Orange stripe
So are you saying that something like this will work instead?
If that's the case, then it would also mean I would have to buy a new fuse of the same type and amperage because the low profile minis that Ford uses won't plug into that tap, correct? Sorry for being dense, but this is all new to me and I don't want to screw anything up.
Thanks.
