4x4 Low
Old Nov 16, 2010 | 07:46 PM
zerick's Avatar
zerick
4x4 Low
Hey guys, I can't seem to get my 4x4 low to engage. When it is in low, it works like in 4x4 high. I'm not sure if it is the motor or maybe the switch. When I switch from <nobr>auto</nobr> 4 to 4 hi, you can hear it click, but it doesn't when I switch to low. I'm not sure if it should or not. My 4 low light comes on when all of the lights on the dash come on before you start, but not when in 4 low. My auto 4 also doesn't engage either. It is just in 2 wheel, but I prefer it that way. I have a 99 expedition 4.6
Anybody have any suggestions?
Thanks,
Zerick
Old Nov 16, 2010 | 08:02 PM
Moto Mel's Avatar
Moto Mel
You will need to get under your truck and inspect the front axle area for broken vacuum lines and while you are there look at the motor and wires on the t/case as well as feeling or inspecting the motor for operation while someone else operates the 4WD switch.
Old Nov 16, 2010 | 08:24 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Sounds like the shift motor is not fully engaging low. It can be removed from the drivers side of the t-case and checked for proper movement.
On the 99 model there is no front axle disconnect so no vac lines to check.
Old Nov 16, 2010 | 08:30 PM
zerick's Avatar
zerick
Figured it out guys. . . I didn't know it has to be in neutral to engage. Guess I haven't been around 4x4 enough.
Thanks for the quick responses though
Zerick
Old Nov 17, 2010 | 06:55 AM
Big Greenie
Yep, the sjift motor can not change to the unsynchronized low range gearset when there is torque being applied, ie; in gear. You need to stop completely, select N, then I ususally let mine roll slightly and you can hear it change to low.
Z94F350
Apr 16, 2014 06:53 PM
zerick
Modular V8 (4.6L, 5.4L)
Nov 11, 2010 04:13 PM
zerick
15
Feb 23, 2010 08:26 PM
cemiii
Jan 4, 2010 07:03 PM
jlv3901
1997 - 2003 F150
Dec 22, 2005 06:34 PM
