I have a 2005 F-350 6.0 Diesel. When I have a heavy load and give it throttle (usually up a grade) the wrench light comes on and I lose most power. The manual says that this is "limp home mode".
My consumer code detector does not show any codes and the problem resets itself when I turn of the ignition and restart the engine.
I plan on going to the dealership, but before I get taken to the cleaners, can I get some feedback and opinions on what this could be?
Thanks,
Rob
Reason: Spelling error.
Welcome to the forum. You found a great place to learn about PSD's. And MOST of the participants are very friendly and helpful. And the ones who aren't usually don't stay around very long.
Sorry I can't help you here, but you might have better luck down in the 6.0 forum.
I don't know when you changed both fuel filters, but I would start their first before going up to the dealer. I don't know what kind of scanner you may have, however I do know the one I have allows me to scan the truck while running and also allows me to monitor certain things on the truck. If you are unable to see the history of the past codes then I would suggest to take the scanner with you and have it hooked up and force the truck to go into limp mode again while pulling and load and scan it to see what the code may be.
I had something like that and the dealer said that the turbo was coked what ever that means.
They mean that the variable vanes in the turbo are blocked by coke deposits similar to what you might see on a BBQ with all the black burnt stuff coating the grill.
in addition to the fuel filters...when was the last oil change. For the 6.0 it takes good oil to run those injectors.
Ford specific codes you need a ford code reader.
It could something as simple as an EGT sensor that is reading too high, when the motor cools EGT's are back to normal so it allows full power, just hard to say.
