6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
limp mode no check engine light
Old May 16, 2013 | 07:59 PM
jagodog's Avatar
jagodog
Wife pulling her horse trailer with her 2008 F450 6.4 diesel. First time truck goes into limp mode, she calls, I show up and find nothing wrong. Start truck and drive home no problems. No check engine light when it happened and on the way home. About a week later it does it again, limp mode and no check engine light. Took it into Ford. Day one only thing on computer was a P1000 code. They could not reproduce the problem. Took it home but they wanted it in again. Day 2 still no problem found. Said drive it and when it happens again do not shut it off and get it to them. Can be a problem if she has horses in the trailer.
Any ideas?
Old May 16, 2013 | 08:40 PM
senix's Avatar
senix
I bet you just need to have this tsb applied...although it should have shown up.
Without the code it is customer pay for the flash.
<table style="border: 2.25pt outset currentColor; width: 96%; mso-cellspacing: 0in; mso-yfti-tbllook: 1184; mso-padding-alt: 2.25pt 2.25pt 2.25pt 2.25pt;" class="MsoNormalTable" border="1" cellSpacing="0" cellPadding="0" width="96%"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="padding: 2.25pt; border: rgb(0, 0, 0); width: 25%; background-color: transparent;" width="25%">
TSB
12-7-7<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
</td><td style="padding: 2.25pt; border: rgb(0, 0, 0); width: 65%; background-color: transparent;" width="65%">
  • 6.4L - LACK OF POWER - DIAGNOSTIC TROUBLE CODE (DTC) P0088 <o></o>
</td></tr><tr style="mso-yfti-irow: 1; mso-yfti-lastrow: yes;"><td style="background: blue; padding: 2.25pt; border: rgb(0, 0, 0);" colSpan="2">[************]Publication Date: July 17, 2012<o></o>[/COLOR]
</td></tr></tbody></table>
<o> </o>
<table style="mso-cellspacing: 1.5pt; mso-yfti-tbllook: 1184;" class="MsoNormalTable" border="0" cellPadding="0"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes;"><td style="padding: 0.75pt; border: rgb(0, 0, 0); width: 172.5pt; background-color: transparent;" width="230">FORD:<o></o>
</td><td style="padding: 0.75pt; border: rgb(0, 0, 0); background-color: transparent;">2008-2010 F-Super Duty<o></o>
This article supersedes TSB 11-4-22 to update the Service Procedure. ISSUE:
Some F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine mayexhibit a lack of power concern with an intermittent DTC P0088; at fulloperating temperature during moderate to heavy acceleration. A calibrationupdate is available to resolve this concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Intermittent P0088 diagnostics: <o></o>
  1. Check all continuous memory DTCs. Is DTC P0088 the only code present? <o></o>
    1. No - this article does not apply, refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual to diagnose this concern. <o></o>
    2. Yes - continue to Step 2 <o></o>
  2. Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 79.05 and higher. This new calibration is not included in the VCM 2012.5 DVD. Calibration files may also be obtained at Buy Motorcraft Parts Online | Official Motorcraft Auto Parts Site | FordParts.com. <o></o>
blacklab1
Feb 19, 2016 02:02 PM
Wbusheyj
Ford In-Vehicle Tech
Oct 31, 2014 02:20 PM
F250OBX
Dec 23, 2007 10:11 AM
Technocrsr
Feb 17, 2007 09:13 AM
kw5413
Sep 13, 2005 02:40 PM
