Timing question
Old Feb 3, 2011 | 08:20 PM
Bear 45/70's Avatar
Bear 45/70
Originally Posted by MONAVIERONJON
Have a powerstroke as well and basically just ear adjusted it as the timing mark is a painted line on the harmonic balancer pulley and it sounded good so just plugged the spout back in and runs good.This is an infrequent driver and could use new plug wires as it is.
Power stroke is a diesel and there is no timing to adjust.
Old Feb 3, 2011 | 10:10 PM
jonbar87's Avatar
jonbar87
You can adjust the timing of the injector pump....not the distributor though. Wait, diesels don't have distributors
Old Feb 3, 2011 | 11:00 PM
MONAVIERONJON's Avatar
MONAVIERONJON
i have 3 trucks,2 460's & a powerstroke.......the diesel runs flawlessly,its the 460 i wuz talkin about.
Old Feb 3, 2011 | 11:51 PM
jonbar87's Avatar
jonbar87
What kind of problems has your 460 given you?
Old Feb 4, 2011 | 07:59 AM
MONAVIERONJON
This is a 90 and timing was really off,perhaps exhaust gasket leak as well contributing to the scenario although unsure as it would be a minor one.There is no marks on the harmonic balancer pulley and actually has a white painted line for tdc.Turned the motor a few times inspecting the pulley for marks and have none.Loss of power being the primary concern.Replaced the distributor a few years ago and has loosened up since it was set then.
Old Feb 4, 2011 | 11:25 AM
Bear 45/70's Avatar
Bear 45/70
If that is the case (which I find doubtful as I have never seen a Ford damper without marks) you need to use an adjustable timing light.
Old Feb 4, 2011 | 09:17 PM
jonbar87's Avatar
jonbar87
I honestly thought i didn't have any marks on mine either until i took a wire brush to it and got rid of a lot of the rust, then i took a marker and marked 10* (or whatever you want your timing set to) so it'd be easy to see with the light.
HP junkie
Aug 30, 2013 04:53 PM
Deeztha1
Apr 23, 2013 03:17 AM
knsahara
Oct 19, 2011 02:52 PM
Saddle Tramp 57
Apr 14, 2006 01:56 PM
wastelands
Oct 29, 2000 11:30 PM
