Sponsored by: Real Truck
Hood release on 2011 F250
Old Nov 15, 2010 | 06:58 AM
BenFranklin's Avatar
BenFranklin
Has anyone noticed trouble opening the hood on their new truck? Normally, when pulling the release in the cab, the hood pops up an inch or two and then you release the latch under the hood above the grill-on most trucks. ON my truck, I pull the release in the cab, and the hood doesnt pop up. I have to force it up, with alot of pressure I might add, to get the few inch gap. Then I release it normally and it goes right up. Is this a fitment issue? Or are all of your trucks doing the same thing. I opened the hood at the dealer, it behaved like this, and the salesman seemed to think it was normal....
Old Nov 15, 2010 | 07:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
Go with the salesman to one or two trucks for sale on the lot and open the hood. If they open the same way, I guess it is normal. If they do not, tell the dealership to fix yours.
Old Nov 15, 2010 | 08:06 AM
cjay84's Avatar
cjay84
salesman here had the same prob on F350 lariat 2011, hard to open hood.
Old Nov 15, 2010 | 08:18 AM
mar66tin's Avatar
mar66tin
my hood easy open, popup 2 inch. your are not normal. you need to fix it !
Old Nov 15, 2010 | 06:40 PM
Mike in PA's Avatar
Mike in PA
My three week old F-350 hood opens
easily. Yours has a problem the salesman
doesn't want to know about.
Mike in PA
Old Nov 15, 2010 | 07:05 PM
cjay84's Avatar
cjay84
it was an instock vehicle, mine is on order....lol
Old Nov 15, 2010 | 07:53 PM
fldave's Avatar
fldave
Mine opens easily, your latch assembly may just need adjusting.
Old Nov 15, 2010 | 11:20 PM
Fordfanatic4life's Avatar
Fordfanatic4life
try making sure the latch assembly and striker area are greased..
Old Nov 16, 2010 | 06:12 AM
BenFranklin
thanks for the feedback guys. I checked and it doesnt seem greased at all. Some all purpose grease do the trick or white lithium or what? Or should I take it back to the dealer incase it actually needs adjusted? I am leery of letting anyone else touch my vehicles...especially bone heads at the dealer...
Old Nov 16, 2010 | 07:19 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
spray a little wd40 on the latch fixes the issue..
Old Nov 16, 2010 | 08:18 AM
DavidB's Avatar
DavidB
Grease
I would try a little grease first. If that does not work, then take it to the dealer and insist on a fix. The WD40 would be OK for a test, but it will evaporate pretty quickly. I lubricate hood latches with spray on white lithium grease. Wipe off the excess. One application last for many years.
Old Nov 19, 2010 | 04:39 AM
countryboy00001's Avatar
countryboy00001
Currently have about 10 new 2011 F250 and F350 and don't have that problem on any of them. Sounds to me like the front catch is out of adjustment. I had the same problem on my 2007 F350 and looked at the front catch, made adjustment and problem went away. Hope this helps
Old Nov 25, 2010 | 03:08 PM
TWF23's Avatar
TWF23
I have not had any problems with my latch but grease may help.
Old Nov 25, 2010 | 10:50 PM
fz1dave's Avatar
fz1dave
Super Duty
I agree with countryboy, adjust your latch. I've had to do it before, though not on my '11.
Old Nov 26, 2010 | 09:43 AM
BenFranklin
Well thanks for the help guys, I just ended up spraying some white lithium grease on the latching assembly. Worked perfectly the very first time I popped the latch, it just popped right up like it is supposed to.
tip49
29
Jul 13, 2017 06:31 PM
three on the tree
Mar 9, 2016 10:13 PM
Trevor.801
Dec 13, 2014 12:57 PM
fossilX
Feb 1, 2012 10:42 PM
4rdnut
May 13, 2011 04:53 PM
