Front brakes frozen?
well to my knowledge you cant adjust the front brakes on this truck. the whole term "frozen" is throwing me a curveball, because i am uncertain of what you are talking about. for instance you problem could be in the caliper itself, wheel bearings, line issues, or a stuck or frozen caliper slide. could you clear it up a little?
Pretty much seems like they are stuck applied. We ended up dragging the passenger front wheel in till it broke lose. Both me and my dad are thinking the calipers need to be replaced.
Brake lines are good, not sure when they were replaced but they are all newer pvc coating hardlines. Master cylinder seems good. The back brakes will work once they are adjusted, and they actuate and return correctly now.
Hope this all helps.
yep calipers.. i had a 91 f350 crew dually lock up the left front wheel one day for no apparent reason. big problem for me was i knew it was tight cause she was pulling to the left but couldnt get out of traffic so i ruined the rotor too. till i got pulled off the highway they were real close to being on fire.
get you some new calipers that will fix you up.
Kelley D
03-30-2017 10:49 AM
Tylus
07-24-2016 09:57 PM
mountain dewd
04-18-2016 06:24 AM
