Short Snout 10.25 vs Long Snout 10.25
Long story short, my '95 pinion bearing is wasted. Has a ton of play side to side and front to back. Also my drums are shot/frozen on axle
Found a '89 10.25 for $150 with good brakes and new pinion seal.
Will my slip yoke be able to accommodate the shorter snout on the '89 axle? I found 1 thread saying yes...but want to make sure
Yes it will work. I went the opposite way on my truck when I lifted it with no ill effects.
That being said, in 1989 the speedometer was read off of a gear in the transmission/transfer case. In your truck, it's read off of the rear end on a tone ring. The 89 axle has no provisions for that.
thx for the confirmation guys. I was aware of the speed sensor...but honestly all my driving is <50 mph here, so I could live without the speedo
I did some door sticker decoding and axle tags...and I have the 4.10 gears with a Dana 50 up front
found another 4.10 axle a little bit closer for $175. gonna pick it up tomorrow. the original 10.25 I found this morning was a 3.55LS.
on
i put a short yoke (1989) axle in place of the long yoke (1993) in chip truck.
parts required:
Carquest Part #2-3050 Rear of Rear Drive Shaft Conversion U-Joint & Moog #331-10 Yoke Strap Kit.
chip truck is a 4wd truck with a slip yoke transfer case.the driveshaft just didn't slide in as far as it used to (but more than enough still)
parts required:
update: Got the axle for $110 with some "slight" rust. supposedly out of a '96 truck, but pinion length is different from my '95 pinion...so I'm guessing it's an older axle. works, so no biggie
got her cleaned up with prodigious use of a hammer and chisel. then all new brake lines and installed.
VSS on the pumpkin works. just need to get that conversion u-joint. it drives around the block right now, but I'm not happy with the slop
on
on
oh cool.i replaced mine last year with a moog.i wrote down moog in my records but forgot the part#.i was at a job and had to pull the rear shaft,lock the hubs and go to the auto store in front wheel drive.replace it and go back to work.in my haste i didn't record to part number......so thanks!
i suppose i could of looked it up and figured it out but i forgot about it.so good to have in my records.
I put a long snout from a '94 in my '89 and had to piece together a u-joint from 3 u-joints. I used 2 small caps from one, the cross from the 2nd one, and 2 caps from the 3rd. There was one listed that was the correct size out of the box but they didn't have it and it was 4 days away by order. Thank goodness I have a very patient parts store to go to!
Bootlegger's Deluxe
06-17-2018 11:45 PM
DumbLuck
01-28-2015 04:09 AM
scottek
11-14-2005 05:17 PM
jonjayjabroni
12-20-2004 10:58 PM
