tensioner pulley squealing
Old Nov 14, 2010 | 11:38 AM
4.0 Beast's Avatar
4.0 Beast
Hey guys, my tensioner pulley (I think its a tensioner pulley - center, mounted high, not turning a pump) is squealing at idle and low speeds. A couple months ago I had it in to the shop and they didn't have a replacement so they pulled it off, and reworked it with some of the parts from a different model pulley and that fixed it.
Today, I just put some coolant into the resovoir and splashed a bit on the pulley and it is squealing again. Can I just spray some lubricant like wd-40 on it? If not, what else can I do? Im trying to get out of going back to the shop for a replacement.
Thanks guys...
97 5.0 Explorer AWD ~176,000 miles
Old Nov 14, 2010 | 11:57 AM
aquanaut20's Avatar
aquanaut20
use a stethoscope and isolate the culprit, if it is the idler and it seizes you will lose the belt and possibly more...
Old Nov 14, 2010 | 12:02 PM
4.0 Beast's Avatar
4.0 Beast
I am 100% sure of where the sound is coming from but I am unsure of what the pulley is. its not the idler because that is at the bottom according to what the mechanic told me.
I have a long trip tomorrow (around 700 total miles) and I wanted to make sure I would be ok. Dont have time to get to a shop beforehand.
Old Nov 14, 2010 | 12:08 PM
aquanaut20's Avatar
aquanaut20
The crank pulley is at the bottom, if it is squeeling only because you have coolant contamination, it will burn off.
Old Nov 14, 2010 | 12:18 PM
4.0 Beast's Avatar
4.0 Beast
when I say bottom, I mean at the lower end of the engine below the ones on the top. I can tell which ones are the water pump, power steering, and a/c. There are like 2 or 3 pulleys that dont turn anything, they are just there for tension or as the idler. This one is one of those that don't turn anything. Hopefully it will burn off like you said. I used a hose and thoroughly squirted water to clean the coolant off of everything.
Old Nov 14, 2010 | 01:31 PM
caseys's Avatar
caseys
...when I thought it was my idler squeeking... I used the stethoscope and pin pointed the problem to be the cam sensor, replaced the cam sensor and all is well.
Just a thought...
Old Nov 14, 2010 | 08:22 PM
steve(ill)'s Avatar
steve(ill)
if it started squeeking just when you added antifreeze, you spilled it on the belt. spray dishwater soapy water all over it, then flush with clean water, then let it dry and squeek will go away.
sharkattack99
Feb 17, 2014 12:08 PM
bluemtn95ford
25
Feb 10, 2013 11:30 PM
00GT
1983 - 2012 Ranger & B-Series
13
Jun 3, 2011 11:11 PM
BarnieTrk
Nov 8, 2010 04:47 PM
Paul-FL
Apr 3, 2009 08:00 PM
