What is best belt dressing?
Old Nov 4, 2010 | 02:39 PM
BarnieTrk's Avatar
BarnieTrk
Fellas,
The serpentine belt on my '05 6.0L diesel is squealing like a blue Jay caught in the talons of a Red-Tailed Hawk!
The tensioner was shot so I replaced it about three weeks ago, and I thought that it might quiet the squealing some - no dice. It is squealing just the same! I inspected the belt at the time of the tensioner R&R and it looked fine - no cracks on the front or back. I suspect that the smooth side was subjected to glazing when the tensioner was bad. It does quiet down in the rain, so I don't think it's one of the other pulleys.
So Guys: What is your favorite belt dressing you'd recommend that I could apply to the belt to reduce all the noise?
BarnieTrk
Old Nov 4, 2010 | 03:57 PM
TYZ78F150's Avatar
TYZ78F150
New belt time.
Old Nov 4, 2010 | 04:20 PM
tdappleman's Avatar
tdappleman
Don't use belt dressing - some are simply silicone based like tire shine and others provided a tacky surface that supposedly keeps the belt from slipping. None of it works beyond the initial spray - but at least it usually gets all over your engine. I've cleaned too many customer vehicles which have it all gummed up on pulleys, etc and they still need the belt replaced. Get a new belt and make sure it's a quality one - like Gates to get rid of the noise.
Old Nov 5, 2010 | 07:51 AM
BarnieTrk's Avatar
BarnieTrk
TDappleman,
Yeah, that is what I suspected.
Dang! - I'm not looking forward to changing the belt on that EB-loaded, 6.0L !
Have you got any secret method you can share to go about changing the serpentine belt?
BarnieTrk
Old Nov 5, 2010 | 04:37 PM
tdappleman's Avatar
tdappleman
The best thing I can say is get the tool or at least a long handled 3/8" ratchet to make the job a little easier. I have the Gear Wrench set at my shop and it only takes about 10 minutes to change the belt on one. The worst thing for me is getting interrupted in the middle of a job and then having to come back and already forgetting the layout. The diagrams don't replace the memory of how it just came off!
Gear Wrench set: SPECIALTY TOOLS > Serpentine Belt Tool > | GearWrench™
Old Nov 5, 2010 | 09:38 PM
UrbanXX's Avatar
UrbanXX
The best belt dressing I have found is a light coat of regular hand soap (not wet). Dial works good.
Old Nov 6, 2010 | 05:32 AM
jdadamsjr's Avatar
jdadamsjr
I would recommend not using belt dressing... or at the very least use is sparingly !
belts need SOME slip to handle the loads, make it too tacky and the belt will snap -
no matter if you have 6 people in tux and gowns going to a wedding !!!!
and WOW, what a noise it made when it went !
and WOW, what a time getting the beast turned and stopped !
Old Nov 6, 2010 | 09:20 AM
cficare's Avatar
cficare
If you're going to use belt dressing, try WD40. Me? I'd replace the belt.
Old Nov 6, 2010 | 11:12 AM
ibyourhucklebery's Avatar
ibyourhucklebery
NO!!! Not WD40,, will do nothing but attract dirt...but will dispace water very efficiently.. Just get a new belt..my Z28 was horrible with that until i replaced the tensioner and belt.
Old Nov 7, 2010 | 07:00 AM
Snowseeker's Avatar
Snowseeker
Bar of soap.
Old Nov 8, 2010 | 04:47 PM
Skullonarm's Avatar
Skullonarm
Belt dressing is snake oil. Don't use it. sometimes even after replacing the serp belt you will get the squealing. It's not easy, but totally clean all your pulley's that have groves in them. I have done this a lot when I worked as a tech at a dealership. I would remove the serp belt, then use brake clean and wash off the pulley's followed by a compressed air blow off or a good wiping down of each pulley with a clean rag. Cleaning the pulley's is often overlooked, but I would bet their dirty. Oh and replace your your belt.
twangysmitty
24
Feb 20, 2024 06:03 AM
94150
15
Jan 25, 2017 03:41 PM
Icefan71
1997 - 2003 F150
Jan 15, 2017 07:52 AM
CoreLokt
Mar 14, 2016 06:13 PM
Ron94150
Oct 5, 2015 11:28 AM
