1978 - 1996 Big Bronco
timing chain?
Old Nov 14, 2010 | 12:48 AM
bronco#7's Avatar
bronco#7
sorry meant camshaft not the ever elusive crankshaft and i dont really want to hear that it could be a broken camshaft either> ive started drinking now so please reply before i start making even less sense
Old Nov 14, 2010 | 08:08 PM
thecardoc's Avatar
thecardoc
If the oil pump locked up it will shear the roll pin holding the distributor gear on . With that pin being sheared there is no connection to turn the distributor shaft and no rotor turn . No rotor turn then no spark .
I would look down the open distributor hole and watch the gear ( which is the camshaft ) to see if it turns while cranking the starter. If it does not turn you probably have some plastic teeth worn off the cam sprocket and are going to need a new timing chain set. Chain very seldom ever break but the sprocket teeth do fail then the chain slips.
But don't rule out that flux capacitor.
Old Nov 20, 2010 | 03:08 PM
PIKE's Avatar
PIKE
Is the Flux Capaciter inside of the black tomato juice can on the paasenger side inner fender? How much resistance should I get with my Multimeter?
Old Nov 24, 2010 | 11:48 AM
maxbodyworks's Avatar
maxbodyworks
Sounds freakishly like what i am dealing with,....check my post's ,...breaking brand new starters,..
riverguideguy
May 10, 2013 08:28 PM
onefut
Aerostar
16
Jun 23, 2004 10:04 AM
Whip1
Bronco II
Jun 10, 2004 07:18 AM
14 Fords
Mar 7, 2004 12:58 PM
tongie607
Jan 19, 2002 08:15 PM
