Torque converter?
Old Nov 13, 2010 | 03:46 PM
Sparx Macgyver's Avatar
Sparx Macgyver
Question Torque converter?
OK, so I've got it on, but somehow it doesn't seem right. I'm not sure it's entirely in all the way. it wobbles just a bit (like up down motion) and is a bit hard to turn. I've been pushing and turning but it won't go in any further. Dunno, just seems like it's not on all the way.
Is it supposed to be in like 3 inches or something? I'm trying to figure out how to tell if it's in all the way.
Old Nov 13, 2010 | 09:18 PM
bmuhlbach's Avatar
bmuhlbach
measure the flywheel to the block . thats what the torque converter should be from the trans to to the front of t.c.When you put the t.c. in it should click in 2 times.
Old Nov 13, 2010 | 10:24 PM
Sparx Macgyver
That's what I thought, it's just not going in.
Old Nov 13, 2010 | 10:48 PM
bmuhlbach's Avatar
bmuhlbach
you have to turn it and wiggle and push it in.should ingage !!! Good luck
Old Nov 13, 2010 | 10:51 PM
Sparx Macgyver
Thanks. It's being a royal [bleeeeeeep].
Old Nov 14, 2010 | 04:49 PM
Sparx Macgyver
I really hate this effin' T.C. It will not go in. I've been lifting from the center, spinning and pushing so it goes in. Nothing. Am I missing something here?
Old Nov 14, 2010 | 06:37 PM
raystankewitz's Avatar
raystankewitz
some info for you
Make sure the input shaft is all the way in, fully engaged with the forward clutch before trying to get the TC engaged.
IIRC, just the input shaft splines will be visible past the pump snout/stator splines. You should see no smooth shaft at all.
Granted, this is from memory. YMMV.
Ray
Old Nov 14, 2010 | 06:43 PM
bmuhlbach's Avatar
bmuhlbach
measure it out maybe its in all the way.shouldn't go that hard at least they usually don't
Old Nov 14, 2010 | 07:09 PM
Sparx Macgyver
Sadly, it's not working. Looks like it will be off to the wrecking yard. This is a sad day. I can't keep her unless she works, and the landlady will not hear of it unless it can start up and move of it's power. Sunday was my final day given to work on it. It's now passed.
six6six
Sep 23, 2014 12:16 PM
crazn
Escape & Escape Hybrid
Apr 11, 2012 08:19 AM
malib
Mar 8, 2011 11:41 AM
twright05
Nov 20, 2003 12:11 AM
BigMattXXL
Sep 2, 2003 08:15 PM
