My Scangauge II stopped working the other week. (lost power) I figured there was a bad connection at the cable or the SG unit so I disconneted it. Now I go to plug my tuner in to reflash the pcm and it doesn't power up. So it would seem I lost power or have a bad connection at a pin on the OBD port. The scangauge works fine on another vehicle so its a problem with the port.
Is there a fuse for the ODB II port?
I checked the PCM fuse and its ok. The owners manual is vague.
