trans problem?
Old Nov 12, 2010 | 01:37 PM
mr.auto's Avatar
mr.auto
trans problem?
i have a 97 explorer 5.0 auto, when i park on a hill and put thte truck in park it will roll, the only way ive found to keep it from roling is to use the e brake. it runs great otherwise
Old Nov 12, 2010 | 05:48 PM
steve(ill)'s Avatar
steve(ill)
check the linkage at the transmission to see that the selector is going all the way to "park".
Parking pawl - Wikipedia, the free encyclopedia
Old Nov 12, 2010 | 06:03 PM
gstanfield's Avatar
gstanfield
And then when you get it fixed realize that it's a parking brake and not an "E-brake" I always set the brake before shifting to park on everything I won. Why make the transmission take all the abuse of holding the weight of the vehicle when you have brakes to do that!
Sorry, not trying to critisize you, just see a lot of folks abusing their trans by never using the brake.
Old Nov 12, 2010 | 06:06 PM
steve(ill)'s Avatar
steve(ill)
most of the parking brakes are junk and will fall off or lockup in 5 years. If your cable still pulls the brake without dragging and screwing up your discs, your one of the lucky ones... i keep my "e-brakes" in the dumpster at the bottom of the driveway!
Old Nov 12, 2010 | 07:52 PM
gstanfield's Avatar
gstanfield
Whatever works for you, have fun replacing that parking pawl in your trans. I don't know what kind of abuse you encounter to make them (park brakes) break, but mine is still working fine on my 1965 impala, 1979 F-150, 1987 F-250, 2004 Honda Element and 2001 Sport trac. Maybe it's because I actually use them instead of lettting them rust solid.
Did you never wonder why you get that big clunk when you park on a hill and then go to leave and pull the trans outta park? That's a lot of pressure on a tiny little metal finger inside your transmission. After spending over a decade rebuilding engines and transmissions you'll not convince me otherwise. I could always tell when I pulled a trans apart if they used the brakes or not.
Of course you're more than welcome to your opinion.
Old Nov 14, 2010 | 08:36 PM
mr.auto's Avatar
mr.auto
it is engauging all the way, and gstanfield , i see where your coming from,but you offered no help. thx though
Old Nov 19, 2010 | 05:38 PM
gstanfield's Avatar
gstanfield
Yep, no immediate help, just trying to help you from having this issue on down the road and perhaps help others from having it ever. didn't mean to offend if I did.
lew52
2004 - 2008 F150
Jun 25, 2012 01:47 PM
tbm3fan
20
Jul 18, 2011 08:36 PM
Joejoecat
1983 - 2012 Ranger & B-Series
Jun 22, 2011 07:52 PM
twmoss2
2004 - 2008 F150
Jan 30, 2010 10:23 AM
stepasideman
1978 - 1996 Big Bronco
21
Aug 15, 2006 10:55 PM
