Sponsored by: Real Truck
Need help w/ 4x4 problem
Old Nov 12, 2010 | 12:13 PM
REPHOTO's Avatar
REPHOTO
I am a total newby at posting something like this, so if I do something wrong, I'm sorry. I have a 2006 250SD 4x4 PSD with ESOF. Bought it new. Has 50K miles. Also have a 1989 F150 4x4 4.9L w/ 200K miles and a manuel transfer case shifter. I don't use 4WD very often, however when you need it, you need it. Problem is w/ the 250. A couple of weeks ago, I needed to use 4WD Low. When I selected low, it would only go to high. High worked, but it would not shift to low. I've been working on my own vehicles since the mid 60's, so I'm not new to the mechanical world. The only manuels I have are the owners manuels and a Haynes. Obviously the Owners manuel won't help and the Haynes doesn't address my problem other than how to change out parts. I need to find out which part is bad. Can anyone give me some TECHNICAL reference to diagnosing the switch, relays, control module, etc? I HATE going to a dealership.
Thanks
REPHOTO
Old Nov 12, 2010 | 12:22 PM
dchamberlain's Avatar
dchamberlain
The Owner's Manual may very well help you. You can download it here.
https://www.flmowner.com/servlet/Con...ionalEventPage
Many people forget, or don't realize, that you have to have the truck in neutral (or foot on the clutch if manual), and your foot on the brake, before the 4WD Control Module will attempt to shift the transfer case into low.
I've found that occasionally I'll need to let the truck creep just a little, while putting just enough pressure on the brake to activate the switch, when shifting.
Old Nov 12, 2010 | 12:32 PM
thomabb's Avatar
thomabb
Did you have the truck in neutral with your foot on the brake? The ESOF transfer case will not go into 4L unless you do.
Old Nov 12, 2010 | 12:34 PM
thomabb's Avatar
thomabb
Oops, I see Dave already covered that. My bad.
Old Nov 12, 2010 | 01:09 PM
REPHOTO's Avatar
REPHOTO
Thanks for the replies so far. I thought about mentioning that I new about the neutral part of the sequence, but that wasn't the fix. BUUUUUUTT, the creep did the trick. Man do I feel stupid now, but happy.
Thanks!!!
Old Nov 12, 2010 | 01:13 PM
REPHOTO's Avatar
REPHOTO
Oh, by the way, with the manuel shifter on the '89, if it was a little difficult, I did exactly that. Let'er roll.
Old Nov 12, 2010 | 01:15 PM
dchamberlain
It's a matter of getting the gears to mesh. They don't always want to do it by themselves.
I'm finding that the more I use it, the easier it is to get it to shift.
Old Nov 12, 2010 | 01:50 PM
Rick03F250's Avatar
Rick03F250
Don't feel stupid, the only dumb question is the one you don't ask. Sometimes we all have a brain fart.
At least it didn't cost anything to fix!!
Old Nov 12, 2010 | 07:17 PM
lbrjet's Avatar
lbrjet
DChamberlain,
Thanks for the creeping advice. I haven't used my 4lo yet so I'm going to keep that in the back of my head.
Thanks
2010 F250 SC 4X4 5.4L 3.73
Old Oct 30, 2011 | 06:49 PM
s91Ford's Avatar
s91Ford
my 2006 f250 4x4 diesel has esof with auto/manual hubs. up until yesterday all worked fine. i will turn the switch to 4hi light comes on but no 4x4, if i went outside and put hubs in lock then i have 4x4. today i turned the switch while in auto and 4x4 worked, however now with 4x4 disengaged when i make a tight turn it sounds like a crunching sound from front wheels. any ideas..thanks
Old Oct 31, 2011 | 09:41 AM
maverick22's Avatar
maverick22
Probably would get more help if you posted your own question rather than in an old thread, but I'll go ahead and give what help I can. It sounds like the switch and the transfer case all work, so that pretty much leaves the front hubs. Here's a thread about taking them apart - if may be as simple as they need to be greased.
https://www.ford-trucks.com/forums/9...with-pics.html
Old Oct 31, 2011 | 11:31 AM
s91Ford's Avatar
s91Ford
Thanks we just went over the truck and came up with the same answer. Thank you very much for the insight.
Old Oct 31, 2011 | 07:24 PM
s91Ford's Avatar
s91Ford
4x4 problem
Well after changing 1 hub and found it not to be the problem we tested the vac system and found it to be the PVHS. Good luck to anyone with the similar problems, and thanks for the feedback.
robjs111
2004 - 2008 F150
Jun 30, 2010 02:29 PM
Skypilot1957
27
Jan 19, 2010 01:36 PM
Geneoh
Oct 18, 2005 07:36 PM
matt williams
Oct 4, 2004 05:19 AM
Webart
Jul 20, 2003 11:01 PM
