Anthing with a resistor (electric heat) or motor is going to draw more juice than let's say; lights. It will take 1 of your bigger fuses and wires. Don't forget, if you are just adding or changing things going bigger on your wires has no ill effects but the fuse should be in the ballpark. Going with a light fuse can only cause a possible fuse failure. So; big wire+light fuse=mamimum protection. You could always start with a lighter fuse if in doubt.
I have mine hooked up to a 15A fuse with no problem. I can't remember where I got the information, but I think that the heat units draw about 3 amps each.
I am only asking because my uncle is helping me make a custom wiring harness to wire in my driving lights, back up lights, mirror heat, strobes, and aux. power outlets. I need to get all my amp draws and length of wire so we can get it going. Thanks guys..
I need to turn up the heat on my '06 mirrors. My '04 would make water and ice vaporize easily but these '06 barley get warm.
There isn't a way to "turn it up", the heater grid does the work and it's either on or off. My assumption would be the heater grid isn't as dense or powerful in your 06 as in your 04, and they probably did that due to them getting too hot and cracking mirrors or burning out prematurely. Doesn't help that they're on all the time unless you install a switch like I did...
As far as current draw, I've heard 4 amps each, but not sure where I heard that. Next time I have my dash pulled off (soon, as I need to install another switch for lights), I'll pop the multi-meter on in place of the switch and see how many amps they pull...
How did you install a switch, i have been wanting to do that too! and couldnt find anything on it. thanks in advance.
There are two easy ways depending on whether you have a spare Upfitter Switch available or not. If so, pull fuse #39 and replace it with a blown 15 amp fuse. Any good parts store will have micro fuse circuits taps available - they're little brass strips with a slit on one end for the leg of the fuse to pass thru and a tab on the other end for a 3/16" push-on wiring terminal. Stick the tap on the leg of the fuse going to the mirror heater and connect a wire from one of your upfitter switches to the tab. You now supply power to the mirror from the upfitter switch.
The other way is to also use a blown fuse in #39 but use two taps - one on either side of the fuse. Wire from one side, thru a seperate 15 amp fuse to a switch and then back to the other side of the fuse.
I used the first method. To return either method to stock just remove the bad fuse and replace with a good one.
I'll have to find the thread again, but it's a purple wire if I remember right, behind the fuse box. I just cut the wire, and ran 2 jumper wires (one from each end of the cut wire) out to the dash and installed a lighted switch. Pretty easy, total time probably under 1/2 an hour... You could use an upfitter switch too, but I'd still do the wiring on the back of the fuse box.
No offense pupnduck, but that sounds tacky, putting in a blown fuse and running those fuse tap things. For the extra time it takes to undo four bolts and pull the fuse box down, it's worth it.
Green wire with Purple tracer, in the 12 pin connector, directly behind fuse #39. You can just remove the fuse and connect the upfitter switch (for which the wire ends are right there anyway) into that wire with a simple wire tap. Very very simple.
