E4OD Engine Braking Problem
Old Nov 12, 2010 | 09:04 AM
subford's Avatar
subford
When I start to go down a hill in OD 4th gear and shift to manual two for engine braking the transmission skips 3rd and goes from 4th to 2nd with no pause at 3rd. It may even be going all the way from 4th to 1st.
This runs the engine to a very high RPM.
Why is it NOT going into 3rd until the speed is down and then go into 2nd?
Could this be caused by a bad TR sensor?
This is a 1994, 460, E4OD with a 5.13 rear end.
Old Nov 12, 2010 | 09:29 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Go out of OD BEFORE you shift the lever to manual anything. Been a while since I've had the E4OD, is there another position before two? I believe that the manual shift will try to go to whatever position you put it in - if the speed is not TOO high. As soon as it gets to a pre-determined speed, it will go to the position selected. Manual is just that....
Old Nov 12, 2010 | 09:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Because that's the way it was designed. It won't run the engine speed too high, though it may be higher than you like. To get to third gear turn off the overdrive with the switch on the end of the shifter.
Old Nov 13, 2010 | 05:42 AM
subford's Avatar
subford
Thank you both for your posts.
Kws3sc
Jul 19, 2022 05:53 PM
Laneely84
Oct 27, 2015 05:12 PM
shadetreescotty
Jun 24, 2015 04:52 AM
plowboycowboy
Mar 29, 2015 12:09 PM
plowboycowboy
Oct 10, 2014 09:57 PM
