no 3rd or 4th gear?
Old Jun 24, 2015 | 03:33 AM
shadetreescotty's Avatar
shadetreescotty
Exclamation no 3rd or 4th gear?
I have a 96 f150 with 4.9l and 2wd e4od. I recently developed a transmission leak from the bell housing. Transmission operated correctly until I towed vehicle to a shop and then pulled tranny and replaced front and rear seals and the rear main engine seal (since I was there). After replacing seals and checking/ adding fluid then running through the gears. everything seemed fine until I took her on the highway. It never shifted into 3rd or 4th and the leak was fixed.I then removed tranny again. drained torque converter. checked internals of torque converter and all electrical plugs. reinstalled tranny after finding no apparent issues or damages. I then connected obdII scanner for codes and got none. no flashing OD lights. no noises. no trouble shifting into reverse or 1st and 2nd. no clue where to go from here. any advice would be greatly appreciated.
Old Jun 24, 2015 | 04:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My guess is a stuck 2-3 shift valve in the valve body.
BDFD
18
Mar 26, 2021 12:42 PM
therigwelder
1997 - 2003 F150
May 2, 2017 10:23 AM
HMS
Jul 11, 2013 10:14 PM
73strokin
17
Jan 25, 2013 03:15 AM
cowboy133
Jan 23, 2005 05:36 PM
