1978 - 1996 Big Bronco
new find
Old Nov 17, 2010 | 10:05 PM
husker's Avatar
husker
leaks at carb could be a bunch of stuff, but probably is a blown diaphram. Carb probably is all dried out and needs a cleaning and/or rebuild. Will the engine fire if you use starting fluid?
My old 78 Bronco usually gets a shot of starting fluid the first time I start it, if it has been sitting for a month or two. Just makes it easier to fire up. Then it is OK if I drive it every few days. I just may let it sit for a month or two at a time. I use it mainly to play off road and to do some rock crawling. It is bunches of fun, but the body is pretty beat up.
Old Nov 18, 2010 | 07:36 PM
jacfordf-250's Avatar
jacfordf-250
I was think cleaning it and new gaskets might work
Old Nov 25, 2010 | 04:13 PM
jacfordf-250
i got used carb from the junk yard it a holley card no sure where the vacuum lines go to?
Old Nov 30, 2010 | 08:20 AM
jacfordf-250
new carb is on .the truck canks but won't start. any ideas why?
Old Nov 30, 2010 | 09:29 AM
g_k50's Avatar
g_k50
Distributor
Old Nov 30, 2010 | 01:20 PM
jacfordf-250
carb is leaking gas again
Old Dec 3, 2010 | 05:45 AM
jacfordf-250
i order a new carb from napa yesterday.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
