1978 - 1996 Big Bronco
new find
Old Nov 8, 2010 | 07:16 PM
jacfordf-250's Avatar
jacfordf-250
new find
i found a 78 ford bronco with 71,000 and very little rust . I need get it started it been sitting for a year
Old Nov 8, 2010 | 07:55 PM
American Thunder's Avatar
American Thunder
Wow, nice! Pics??
Old Nov 9, 2010 | 04:28 AM
jacfordf-250
now yet to dark last nite
Old Nov 11, 2010 | 07:32 PM
jacfordf-250
i got my bronco tonite. now to find why it not getting gas
Old Nov 12, 2010 | 06:12 AM
jacfordf-250
any idea why no gas i put in 5 gal.
Old Nov 12, 2010 | 07:36 AM
Encho's Avatar
Encho
The Southernmost Mod
Maybe it had old gas, wich won't help you start the truck, dump all the gas and replace it with fresh gas, change the fuel filter also, hit the fuel tank a couple of times firmly (maybe the pump got stuck for the lack of use), check the lines and fuel pressure (it should be near 39 PSI), check the pigtail connector to the pump if it's an electrical one. if nothing else works, or you still get no pressure, swap the fuel pump.
You could also seafoam the lines in order to clean them, good luck.
Old Nov 12, 2010 | 05:28 PM
thecardoc's Avatar
thecardoc
I don't see how hitting the fuel tank would help anything, seeing as how the the fuel pump is located on the drivers side front of the engine . Fuel pressure should be around 7 PSI (Much higher and it will just push the needle of the seat in the carb.)
Old Nov 12, 2010 | 08:11 PM
jacfordf-250
i was thinking blowing out line from fuel pump back
Old Nov 12, 2010 | 09:54 PM
greystreak92's Avatar
greystreak92
Classic case of "it couldn't hurt". Check for pressure in the line from the pump to the carb. while cranking the engine... take the necessary precautions though please. Wouldn't hurt to visually check for fuel being introduced into the throttle bores when the throttle is cycled either. Lacking pressure in the line to the carb the pump is suspect. No fuel when dumping the throttle could be filter (assuming it is inline between the carb) or a myriad of possible carb issues.
Old Nov 13, 2010 | 01:55 AM
RustyShackelford's Avatar
RustyShackelford
Have you used starting fluid or anything else to run it? Maybe take the line loose at the pump and blow air into the tank to see if you can get gas up there.
Old Nov 13, 2010 | 08:40 AM
Encho's Avatar
Encho
MY pump is inside the fuel tank... I didn't take into consideration it was a 78 when i wrote that part, my bad.
Old Nov 13, 2010 | 11:27 AM
g_k50's Avatar
g_k50
Take the line off the fuel pump that goes to the fuel tank.
Hook up a spare fuel line to the fuel pump inlet into a spare gas tank. The fuel pump will pump fuel out of that tank and not the fuel in the Bronco tank that might be bad.
If the fuel pump sucks the fuel then it's not bad and you can look at the line going up to the carb and if the gas is sprayed into the intake manifold when the accelereator is pushed down then you have gas to the carb.
Then check for spark/timing.
probably has 171,000 on it, maybe even 271,000 but I doubt that.
Old Nov 13, 2010 | 06:21 PM
jacfordf-250
the bronco one family truck since new
Old Nov 16, 2010 | 07:02 PM
jacfordf-250
fix the fuel problem now i need a carb pissing all over the place
Old Nov 17, 2010 | 08:38 PM
Encho's Avatar
Encho
You know? if you don't use any punctuation it becomes a real mess to guess what you're trying to tell us sometimes.
