Ideal Castor Setting?
now I'm just curious, does anyone know the spread of the mounts on stock '05+ trucks on the axle side? I can always peek under a truck, but figure maybe someone knew lol...
Joey
Now go and use your own tape measure.
comments? suggestions? ideas??? first version of the frame side bracket... about 12" long and the bolt hole for the radius arm hangs about 4.5" below the frame... thinking about possibly moving if further back and in the middle? I'll end up modifying this one again and see how I like it... maybe even get the load paths on it...
Joey
first off... bump, lol...
second... picked these up:
2.5x12" sway away coilovers... need a rebuild, revalve, and dual rate hardware and springs... need to figure out what valving I'm gonna run and what springs as well... probably gonna buy all the bushings in a couple of weeks... need to get my bike going again if I'm gonna tear down into my truck before school starts, though! my goal for this project (front only) is 8/26... we'll see how this pans out...
Joey
Joey
rchassie
Sep 11, 2012 12:20 PM
2005, 4x4, adjustment, caster, duty, enthusiasts, f250, factory, ford, forums, ideal, recommendations, setting, super, truck
