True Suspension Level for a 6.2L - Ford Truck Enthusiasts Forums
2017 Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 05-31-2017, 01:38 AM
MadeInDade's Avatar
MadeInDade MadeInDade is offline
MadeInDade is starting off with a positive reputation.
So I'm still six months to a year away from ordering my new Super Duty. After tons of internal debate and struggle, I've decided that the 6.2L is the better option for me. That said, I'm am one to always do tons of research and buy the best of everything. So it's no different when it comes to my future truck which is why I've been reading everything I can from you guys for the past few months.
I was really set on going with a Carli 2.5" level system with Fox or King Shocks, but I changed my mind from the 6.7L PSD to the 6.2L gasser and Carli doesn't make any products for the gassers.
I then found Filthy Motorsports and they seem to have some really nice custom tuned King Coilovers and shocks for the 6.2L. My truck will spend 95% of its time on the street and I'm mostly looking for a better on-road ride with a little off-road capability (light trails, camping, hunting). I like that you can customize your ride height with the coilovers, but I don't think I need coilovers and shocks for what I'll be doing with the truck. So I've been thinking about replacing the stock ford coils with some taller ones to give me a 1.5" - 2.5" lift in the front and then pair them with some 2.5 King Shocks. The problem is, I can't find anyone selling high quality linear rate coils that give that slight lift up front. All the levels I'm find for the gassers are just spacers/blocks. Does anyone know of a top notch company that sells new coils that will give me a 1.5" to 2.5" lift up front?
Also while on the subject, any recommendations for softening the ride with the rear suspension? I plan on doing King Shocks in the rear too, but am open to replacing the rear leaf springs if it's needed. I'm not worried about losing a little towing/hauling capability if I can gain significant ride quality. It seems like Carli is the best place to go for everything if you have a 6.7, but looks like I will be stuck piecing the best products together from different sources for the 6.2L.
Old 05-31-2017, 08:53 PM
Bruce Kerr's Avatar
Bruce Kerr Bruce Kerr is offline
Bruce Kerr is starting off with a positive reputation.
What are your thoughts on BDS? They have 6.2 options.
Scratch that, their 1" and 2" are spacers.
Old 05-31-2017, 09:54 PM
MadeInDade's Avatar
Yeah same with Wicked.
Old 06-01-2017, 12:40 AM
OR2BAJA OR2BAJA is offline
OR2BAJA is gaining momentum as a positive member of FTE.OR2BAJA is gaining momentum as a positive member of FTE.
If you are a squeaky wheel and are local in socal I bet you could convince Carli to work on something. I would like to get a high mileage 6.2l super cab, short bed work truck here in the future and make it my Baja rig essentially recreating what my out going dodge is. Pull the motor, rebuild it and make a cool project out of it.
Old 06-01-2017, 12:44 AM
In regards to the rear...
If I were you I would call Carli and order either the leaf pack or see when the full deaver leaf will be available. With a Carli Deaver setup, you retain most of the load capability but benefit from the combo the leafs and shock combo.
Another option is to pull some leafs from your stock setup.
I would look at the Carli radius arm as another upgrade. You are missing front coils and shock valuing, everything else is or will be available.
Old 06-02-2017, 03:10 AM
MadeInDade's Avatar
Just an update:
I found some 1.5" leveling coils from Rough Country. They create a 1.5" lift for the diesels, so maybe it'll give a 2.5" lift on the gassers. So far they are the smallest lifiting coils I've found though I would like to find something higher quality than Rough Country.
1.5in Leveling Coil Springs Lift Kit for 05-17 Ford 4wd F-250 / F-350 Super Duty [9285] | Rough Country Suspension Systemsģ
Old 06-18-2017, 08:23 PM
Rebel 84 Rebel 84 is online now
Rebel 84 is starting off with a positive reputation.
So what happened?
Old 06-18-2017, 09:14 PM
MadeInDade's Avatar
Quote:
I live in South Florida, far from SoCal. And I reached out to Carli a couple months ago about 6.2L options, but I got no response.
Quote:
Originally Posted by Rebel 84 View Post
So what happened?
Nothing. I have yet to find a solution, but I'm still searching.
Old 06-19-2017, 06:25 AM
Hackenbush's Avatar
Hackenbush Hackenbush is online now
Hackenbush has a good reputation on FTE.Hackenbush has a good reputation on FTE.
Just an update:
Nothing wrong with the RC 1 1/2" Coils for the 6.2 they raise it 1 1/2" I have them on a couple 2017's 6.2 trucks.
Old 06-19-2017, 08:01 AM
windellmc windellmc is offline
windellmc is gaining momentum as a positive member of FTE.
I bet OEM coils off a diesel would work. The question is which PN? My gasser is pretty level from the factory with the camper package though.
Old 06-19-2017, 11:17 AM
Quote:
Pretty level then?
Old 06-19-2017, 12:44 PM
snelldawg's Avatar
snelldawg snelldawg is offline
snelldawg is starting off with a positive reputation.
Bilstein makes a BTS level kit for the last generation of SD's. Coil over shock kit. Raises the front by 2 inches. I know the front shocks are the same for 2016 and 2017 models, but I don't know if this kit would work or not on a 2017.
Old 06-19-2017, 12:48 PM
Hackenbush's Avatar
About 1" of rake and I have the snow plow package.
Old 06-19-2017, 12:55 PM
MadeInDade's Avatar
Quote:
Iím trying to find better coils than OEM for a better ride. Iím looking for linear rate coils instead of the progressive rate OEM coils. But Iíll keep this on the back burner as back-up option.
Quote:
I know I can do Coilovers. If I do them, Iím going top of the line King 2.5 remote coilovers with King 2.5 remote shocks. But Iím looking at $4k in shocks and coilovers and I donít think I need all of that for my 95% on-road application. Thatís why Iím looking for just the lifted coils and pair them with nice king shocks. But so far the King Coilovers and shocks are the best option Iíve found so they are my first option right now.
Old 06-19-2017, 02:46 PM
MEBE MEBE is offline
MEBE is starting off with a positive reputation.
Skyjacker has 2" lift coils for gas and diesel, using the diesel springs on the gas engine truck gives a 2.5" lift apparently
My 2017 f250 platinum lifted hollywood1981 2017 Super Duty 30 05-20-2017 11:41 AM
Can pick what bilistein shocks to do Vin Diseal 1999 to 2016 Super Duty 2 08-04-2015 07:54 AM
What suspension should I get? 12 F250 Supercab 6.2L Vin Diseal 1999 to 2016 Super Duty 2 08-03-2015 11:14 AM
anyone have carli coil springs and thier leaf springs? ZackYoung 1999 to 2016 Super Duty 1 06-30-2015 07:07 AM
Baja Kits - Ford King Coilover & Shock 4th Of July Sale Baja Kits Vendor Specials, Discounts, Product Announcements & Group Buys 1 07-10-2013 10:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
