I dont use Jasper... not for any other reason than I like my guys...
3yr/100K mile warranty as well.
I installed three engines from these guys so far and only one had a little leak from the oil pan after installation. Put in a new OP gasket and good to go ever since.
go with a ford rebuilt motor. i just helped as buddy do a 5.4 in a 05 E350 van same as a truck jasper wanted 3300 for their crap rebuilt motor. ford wanted 3000 plus everything is new! new valves, springs, and guides plus new crank bearings and crank and a new ford water pump. plus if something is wrong ford will take it out fix it or replace it! if my 5.4 ever goes knockon wood i hope not im going straight to my local ford dealer and order one
