Sponsored by: Real Truck
EGR Issues
Old Nov 6, 2010 | 08:13 PM
Cbronwen16's Avatar
Cbronwen16
EGR Issues
Hello all, My truck is giving me a PO401 EGR fault along with a missfire on cylinders 1 & 3, My question is could the EGR cause the engine misfire? also does anyone have a picture of the EGR location on a 02 f250? I also have a PO316 code for the crank sensor...if anyone knows the position for that i'd greatly appreciate any help.Thanks
Old Nov 6, 2010 | 09:43 PM
2001 bolt's Avatar
2001 bolt
egr is located directly behind the intake elbow it will have 2 8mm bolts to hold it in place and right infront of the oil filter housing...pull it and it is most likely carbonedmake sure you clean the intake...now they can be carboned due to egr and or oil coolers going bad...they will also need to be reset after replacing them...as for the cylinders missfiring it is most likely due to both injectors going bad usually due to low fuel pressure check the fuel quality, filters and fuel pressure...injectors 1 and 3 are both on the right side...hope this helps
Old Nov 7, 2010 | 06:14 AM
wulfman's Avatar
wulfman
just wondering you say 02,and dont say which motor 7.3 has no egr gas motors do. but the info you were given i think is for a 6.0 diesel, just MO, And 02s dont have 6.0s
Chrisdrm10
Aug 6, 2012 06:25 PM
kaw753
1997 - 2003 F150
Apr 15, 2011 12:54 AM
BIGBEAR6
Modular V10 (6.8l)
Sep 6, 2009 02:06 PM
deercreek1
Nov 12, 2007 11:58 AM
