Modular V10 (6.8l)
engine code PO401
Old Sep 5, 2009 | 11:06 AM
BIGBEAR6's Avatar
BIGBEAR6
engine code PO401
Hey guys just had auto zone scan my truck, code 401 egr flow insufficient
about a year ago I replaced the egr valve,dpfe sensor
any ideas what else to look for?
also can I reset the PCM buy touching the + and - battery cables together
I think I read that here some where? disconecting from battery of course.
99 v10
Old Sep 6, 2009 | 12:27 PM
rlh68050's Avatar
rlh68050
DPFE sensor could be bad again. Ford had lots of trouble with these. You can check the DPFE voltage with a good scan tool. You need to look at PID DPFEGR (I think). The voltage needs to be at ~.9-1.0v at idle. If it is below that or over that and the valve is closed the sensor is bad. There is one more component to the system. It is the vacuum actuator. Follow the line on top of the EGR valve. It will be going to the vacuum switch. There will be another line going out of the switch to manifold vacuum source. Make sure all these are intact.
Old Sep 6, 2009 | 02:06 PM
BIGBEAR6's Avatar
BIGBEAR6
Thank you I will check the sensor and all the vac. lines
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
kaw753
1997 - 2003 F150
Apr 15, 2011 12:54 AM
Nitrous
Aug 19, 2007 11:59 PM
fosterwc
1983 - 2012 Ranger & B-Series
20
Aug 25, 2005 06:33 PM
mwear
Modular V8 (4.6L, 5.4L)
Dec 16, 2003 04:49 PM
