Cold start help
Old Nov 6, 2010 | 07:52 PM
Mike F250 SD's Avatar
Mike F250 SD
Cold start help
A buddy of mine has a E series with a 7.3 in it. He can't start it in the morning without pluging it in(it was only 40deg) ? I've never owned a van that was diesel but I think 40deg it should still start after the key has been turned on for the proper amount of time b4 start? The truck runs fine any other time. Any ideas?
Old Nov 6, 2010 | 08:43 PM
F350-6's Avatar
F350-6
He should check the glow plug system first just to be on the safe side. The cold start thread is located here https://www.ford-trucks.com/forums/1...ky-thread.html
How many miles on the van? When it first starts up, does it miss or run a little rough? When it does start, how much smoke is there and what color is it? The 7.3 should start at 40 deg. even without glow plugs. Might be a bunch of white smoke, but it should start. Worn injectors can also cause starting problems that plugging it in seems to fix.
Old Nov 6, 2010 | 09:52 PM
Mike F250 SD
He said white smoke was coming out. Yea we were thinking glow plugs or some thing in the system. I will ask him about the miles and tell his lazy *** to join
Old Nov 7, 2010 | 08:46 AM
HD Rider's Avatar
HD Rider
My truck has 160k+ miles on it now and still starts good. I do ohm out the glow plugs and check voltage drop across the GPR (glow plug relay) every fall. When the temps get into the teens or colder I also wait 10-15 seconds after the WTS (wait to start light) goes out before attemping to start.
Old Nov 7, 2010 | 10:35 AM
clintbonnie's Avatar
clintbonnie
Switching to synthetic oil such as Shelll Rotella 5w40 would help too..
hammer65
55
Sep 21, 2011 05:14 PM
Wayne64SS
Nov 29, 2010 09:42 PM
eric777
37
May 11, 2007 10:16 PM
BowDown
23
Mar 21, 2006 07:05 PM
rlc
Mar 31, 2003 08:21 PM
