I was towing about 12k pounds yesterday and I ended up getting in some stop and go traffic and the tranny temps started climbing. It got to around 230 deg for maybe aound 10-15 minutes. If that happens again, should I pull over or is this okay as long as it's not for a sustained amount of time? By the way, what is the threshold on temp.
( I was in my 40 tow tune and the O/D was on )
I am no expert in this, but two suggestions, larger tranny pan, synthetic trans fluid. The pan helps keep things cooler, the syn doesnt seem to mind higher temps as much, and shortly, you will hear from the pro's....
I agree with Hedhntr above.. change the fluild.. I read somewhere where the oil starts breaking down around 220. I install a extra fan with a crowling around it (under $50 bucks) and mounting it right in front of the transcooler on mine.. I just switch it on when i am driving in stop and go traffic which makes your TC work that much harder and heats the oil..
If it smells burnt, i would change it out.. at least change the just the trans. Probably would only cost you about $20 in oil.. good insurance.. I see by yur signature you don't have an extra trans cooler.. that would also be good insurance to protect your trans and make it last longer.. it's the heat that kills them, so they say.
If I was towing that kind of weight (which i do) I'd do, in this order:
drain/flush/refill the system myself,
install a large tranny cooler WITH a fan (if you will be doing stop & go hauling,
install an external tranny filter and drain system,
top the system off with tranny fluid
An external transmission cooler is a must...but if you do slow speed, dirt roads or stop and go city traffic, the cooler without the fan will likely not be enough. I have never seen above 190 since putting my system together (hauling up the grade out of Laughlin, NV with an air temperature of 110 degrees )! BTW, if you pull over to let the tranny cool down, keep the engine running...the pump in the tranny must be turning to move fluid through the coolers.
Although I never see over 120* on my drive to work (minimal stopping) however in the rat race home, and up a big hill, I can hit 180* if i push it hard (race the riceburners) I was wondering, whats a good synthetic oil to use, and how can I drain the TQ conveter? Any advice on aftermarket large drain pans w/drain plug?
I use this method every year and my feeling is that any synthetic which meets MERCON standards is fine (I believe that it can now meet MERCON V standards, but I can't say that with certainty).
while pulling the 10k lb fifth wheel over a mountain i should have gone around last summer, the tranny temp crested 220 for a short period of time, i have a big tranny cooler added to my mule so the temp came right down as i idled down the other side... (the brakes took that beating...) anyway, i have mobile synthetic in the tranny and it only had 20k miles or so on it... i checked my mule over thoroughly after that little trek... the fluid has a slight, and i mean very slight smell to it like it was thinking about burning, but i don't think it did, syn fluid is supposed to be good to 250 degrees, although i know the seals in most trannys do not do well at that temp... so... since then, no fluid change, no difference in the smell of the fluid, and no difference in the performance of the tranny at all... i am, however, VERY happy i spent the extra money on the synthetic fluid AND the big tranny cooler, AND the tranny temp gauge...!!!
