truck overheats
Old Mar 31, 2003 | 12:02 AM
rlc's Avatar
rlc
truck overheats
most of the time it's not a problem,but any kind of steep,slow grade and it over heats even on a 40deg. day. only has a single row radiator.would a double row be the answer?
Old Mar 31, 2003 | 08:21 PM
Ultramagdan's Avatar
Ultramagdan
Talking truck overheats
Hi rlc and welcome to FTE!
You have a few things that could be happening.
1: A steep slow grade is going to reduce the amount of air going through your rad.
2: You probably don't have a fan shroud - which would help the fan pull the air through the radiator.
3: You truck is old enough that you may not have a efficient water pump and it is causing cavitation.
4: Your water pump belt may not be tight enough and is slipping.
5: A double core would help if the rest of the system is okay.
OleGrouch
Jul 27, 2012 02:03 PM
cmachk
May 3, 2007 07:05 PM
BottomFeeder
May 13, 2006 10:14 PM
gblakeney
Jan 27, 2006 06:43 AM
jluttrell
Sep 13, 2004 02:06 PM
