Bronco II Ford Bronco II
rear end swap
Old Nov 6, 2010 | 04:31 PM
mudslinging79's Avatar
mudslinging79
rear end swap
ok, got my exploder rear end to stick in the bronco2, can one just swap it for endo, and flip it over instead of cutting and re-welding axle spring mounts?, basically swap ends left side to right and flip it over so pumpkin is pointed the right way???
Old Nov 6, 2010 | 04:36 PM
fabmandelux's Avatar
fabmandelux
FTE Remembers
Drive will be backwards. Think about it.........
Old Nov 6, 2010 | 06:13 PM
Old93junk's Avatar
Old93junk
He would not be the first one, I have heard of a similar project getting all the way to trying to back out of the shop, before figuring this little engineering gem out!
Yes, its time for some griding and welding.
Old Nov 6, 2010 | 07:30 PM
Eddiec1564's Avatar
Eddiec1564
If you don't want to cut and weld spring mounts, I have heard of others getting "high arch" springs and mounted the explorer axle like normal. Other than that, its cut and weld time as your B2 don't have clearance with the over slung axle.
Old Nov 6, 2010 | 09:19 PM
mudslinging79
well, im already running the explorer springs, would i be able to run it like normal then?
Old Nov 7, 2010 | 02:00 PM
mudslinging79
ok, got my sprong mounts ready o be welded, i noticed the plate the driveline bolts to is larger than my stock one. my question is, can i replace the yoke that bolts to the plate and keep my driveline, as its fairly new, or do i need to get another whole driveline???
free72
Dec 19, 2014 06:21 PM
crashandburn133
Nov 29, 2010 07:38 PM
custom cabby
Mar 17, 2010 06:55 PM
71fordkid
Oct 12, 2007 09:44 AM
460
Offroad & 4x4
Aug 27, 2006 10:00 AM
