Need help asap. Please read.
Old Nov 6, 2010 | 03:12 PM
2006powerstroke90's Avatar
2006powerstroke90
Well my radio was not working in my 2006 ford f350 6.0 Traced it to the fuse. Put a new fuse in and now the truck will not start at all.
Any body have any ideas? It cranks and cranks. But will not start at all.
Not even with a shot of either.
Please help.
Old Nov 6, 2010 | 03:16 PM
bismic's Avatar
bismic
Have you checked all other fuses and relays?
Old Nov 6, 2010 | 03:22 PM
2006powerstroke90
Yes. I checked all the fuses and relays. And the fuel shut off thing. I reset that. Any certain fuse or relay to look out for?
Old Nov 6, 2010 | 03:30 PM
bismic's Avatar
bismic
I would make sure all relays are fully seated and not overly hot from cranking.
That being said, I guess it is time to start at the basics - fuel and electricity. Batteries in good shape (even though it can crank doesn't mean that they are good enough), FICM producing proper voltage, fuel getting to the engine (ie will it fill the secondary fuel filer at KOEO), then you need to start looking into oil flow and pressure.
There is a no-start thread in the Tech Folder that will walk you through most of the things that can cause it not to start.
Old Nov 6, 2010 | 03:45 PM
2006powerstroke90
Well the guy helping me had to go so we will try again tomorrow. I bought the truck with the radio not working. Realized the fuse was missing put one in and then the truck was dead. But I'm pretty sure that wouldn't have anything to do with that...?
What kind of voltage should the ficm have to it? And I know the filter on the top of the motor has fuel. It was full
Old Nov 6, 2010 | 04:13 PM
DPorter's Avatar
DPorter
have you tried it without the radio fuse?
Old Nov 6, 2010 | 04:22 PM
2006powerstroke90
Yes I did. I don't think it could be the icp sensor either. While cranking my oil pressure was reading what it normally does. Very dissapointing sold my cummins for this
Old Nov 6, 2010 | 04:51 PM
bismic's Avatar
bismic
You really need to read up on the 6.0L engine since you are new to it. Your OEM engine oil pressure reading is not at all what the ICP measures. The ICP measures the high pressure oil pressure. Your injectors are actuated hydraulically - w/ oil at high pressures.
The OEM oil pressure gauge isn't a tru gauge either because the sending unit is just a switch - so you are not looking at real pressure readings.
You really do need to look at the Tech Folder- specifically the no-start thread if you are serious about troubleshooting the problem yourself.
Old Nov 6, 2010 | 04:57 PM
cheezit's Avatar
cheezit
can you pull codes and with a scan tool? and does the cig lighter work?
Old Nov 6, 2010 | 05:17 PM
2006powerstroke90
I will bring the laptop to the shop the truck stopped running at tomorrow.
It has NO codes, checked it with 2 different scanners.
I will do the NO START tomorrow. With the ICP.
So it cold be the HPOP? ICP?
Just trying to get an idea what to look at first to hopefully get the problem solved asap.
What if the cig lighter worked/didnt?
Old Nov 6, 2010 | 05:19 PM
cheezit's Avatar
cheezit
that is hooked in to the dlc. so that would give an indaction of a concern.
also when you check the rest of the fuse did you use a test light or did you you pull them out and check them with an ohm meter.
Old Nov 6, 2010 | 05:37 PM
2006powerstroke90
Sorry for the newbie questions but I do not know much about powerstrokes at all.
Whats a DLC? I tested them with a test light and pulled them out one by one and inspected them.
Whats the difference between a ICP and a HPOP?
Also if they're bad that would cause the truck to not start with either?
Old Nov 6, 2010 | 05:41 PM
cheezit's Avatar
cheezit
dlc = data link connector. this is were you hook a scan tool up at
hmmm icp.ok you asked
the icp reads what the ipr is metering that the hpop is making.
if you dont follow that lat me know and all expain as best as I can
Old Nov 6, 2010 | 05:45 PM
2006powerstroke90
Whats the IPR?
What goes bad then the ICP or the HPOP?
And it wont start on starting fluid if their bad?
Old Nov 6, 2010 | 05:48 PM
cheezit's Avatar
cheezit
ipr = injection pressure regulator.
any of the above can go "bad"
Have you reviewed the tech folder yet. a read of the coffie table book has most of the parts, sensors, etc listed and a brief discripition of them
