Need help asap. Please read.
Old Nov 6, 2010 | 05:50 PM
2006powerstroke90's Avatar
2006powerstroke90
So if I unplugg the ICP the truck should start if thats bad?
I would just like to get the truck to my house with out a tow.
Old Nov 6, 2010 | 05:51 PM
cheezit's Avatar
cheezit
that is mostly correct. but that is an indacator of a failed icp sensor.
Old Nov 6, 2010 | 06:11 PM
2006powerstroke90
Now can you tell me where this is located and what it looks like?
If I unplug it and then the truck starts then its that?
Now what if I go to the truck tomorrow morning and it starts up without doing anything?
Old Nov 6, 2010 | 06:25 PM
cheezit's Avatar
cheezit
its in the tech folder that I suggested you look at.
its on the right valve cover, its the only sensor that goes thre the valve cover on that side. it has 3 wires and next to it is the gpcm.
Old Nov 6, 2010 | 06:50 PM
2006powerstroke90
Alright I will test that out tomorrow and see what happens.
Hopefully its that, that sounds like its an easy fix, I hope?
If I do unplug that and nothing changes what do you suggest I look for next?
I did read that article but I do also like to be able to talk to someone about it also.
You have been much help
Old Nov 6, 2010 | 06:57 PM
bismic's Avatar
bismic
Two necessary resources - both easily found through Google:
6.0L Bible
6.0L Coffee Table Book (as cheezit mentioned, it is also in the Tech Folder)
Old Nov 6, 2010 | 07:25 PM
2006powerstroke90
Page 11: Component Locations
That says the ICP is under the turbo?
Old Nov 6, 2010 | 08:35 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
On '03's and early '04's, yes - but on your '06 it's on the passenger's side valve cover. You need to look at the "2005 6L Bible Update" link in the Table Of Contents for the correct component locations for your Model Year.
Old Nov 7, 2010 | 06:42 AM
2006powerstroke90
Well I unplugged the icp sensor and it still did not start.
Also when turning the key waiting for the glow plug light to go off and I don't hear that buzzing noise it usually made.
Would taking the radio out put the truck into some kind of safe mode?
Old Nov 7, 2010 | 07:26 AM
2006powerstroke90
Well I now know that it's not the icp or the hpop. The relay under the hood on the right side of the motor looking at it is not working. If we pull the first relay on the left side does not have power going to it if we pull it out with the key on. If we jump it the truck starts right up. Any ideas?
Old Nov 7, 2010 | 07:35 AM
npccpartsman's Avatar
npccpartsman
You need to check the FICM, FICM relay, etc. because it's the injectors that make the buzzing sound at start up. Also, check your fuel pump if you can't hear it. If the cigar lighter isn't working then the OBDII port/ DLC connector probably won't work because of a blown 10a fuse that I think is listed as cigar lighter in the manual. Don't remember the fuse number off the top of my head. Sounding more and more like electrical problems here.
Old Nov 7, 2010 | 07:40 AM
cheezit's Avatar
cheezit
Originally Posted by cheezit
can you pull codes and with a scan tool? and does the cig lighter work?
that was covered in post #9
Old Nov 7, 2010 | 07:45 AM
  #28
2006powerstroke90
How do I check the ficm and where is the relay for it?
Old Nov 7, 2010 | 07:46 AM
  #29
cheezit's Avatar
cheezit
ficm relay is the grey one. under the hood iirc. to check the ficm there is a bunch of threads on it. use the search function.
Old Nov 7, 2010 | 07:48 AM
  #30
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
The tech file is a great tool also.
https://www.ford-trucks.com/forums/8...procedure.html
