Steering wheel compatible
Old Sep 25, 2012 | 12:09 PM
  #31
Bobs61's Avatar
Bobs61
I am looking to see if ford made a truck in the 70s with power steering with a 4 speed
Old Sep 25, 2012 | 12:13 PM
  #32
Blown 331's Avatar
Blown 331
Yes they did, lots of them. I have 2.
Old Sep 25, 2012 | 05:29 PM
  #33
Bobs61's Avatar
Bobs61
I am trying to find some information on getting a column for my truck it has a manual steering and I want power and keep the 4 speed, It is a 2 wheel drive , I have the gear box need pump and brackets to mount the pump to a 390
Old Jan 31, 2013 | 09:24 PM
  #34
Lawspawn's Avatar
Lawspawn
Does 65 Mustang wheel fit 66 F100?
C3DZ3600A .. Black Three Spoke Steering Wheel / Obsolete-Reproduced by Dennis Carpenter.
Fits: 1961/66 F100/250 2WD / 1966 F100 4WD / 1967/70 F100/250-all / 1969/70 F350 / 1960/63 Falcon/Comet / 1966/73 Bronco.
Custom Cab's have a horn ring, Standard Cabs have a horn button. Bronco's all had a horn ring. Falcon/Comets came with either, depending on the model.
All: 1961/65 F100/250 4WD; 1961/68 F350/600; 1966 F250 4WD used a four spoke steering wheel-all with a horn button.
1971/77 F100/350 steering wheels are two spoke, use a vinyl horn pad/switch and are the same as 1974/77 Bronco & 1975/77 Econoline, except 1975/77 F100/350's & Econolines with Speed Control.
Regardless of what steponit claims, the steering wheel used with Speed Control on 1975/77 F100/350's and Econolines is different than the non Speed Control steering wheel.
D4TZ3600A .. Two Spoke Black Steering Wheel / Use without Speed Control / Fits: 1971/77 F100/350; 1974/77 Bronco; 1975/77 Econoline / Obsolete-Reproduced by Dennis Carpenter.
D5TZ3600A .. Two Spoke Black Steering Wheel / Use with Speed Control only / Fits: 1975/77 F100/350 & Econoline / Obsolete
And...D5TZ13341B .. Turn Signal Switch / Use with Speed Control only / Fits: 1975/77 F100/350 & Econoline / Obsolete
Old Dec 9, 2017 | 07:15 PM
  #35
columbia1spring's Avatar
columbia1spring
I was going to replace my steering wheel wiring because the turn signal cancel cam won't cancel. I can across this old thread and I have a 78 steering wheel on my 74. Am i to believe all I need to do is find a 74 steering wheel and everything will work again?
Old Dec 10, 2017 | 11:28 AM
  #36
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Same 2 spoke steering wheel: 1971/77 F100/350; 1974/77 Bronco; 1975/77 Econoline except 1975/77 F100/350 & Econoline with Speed Control.
1973/77: Three different T/S switches: A/T; M/T; 1975/77's with Speed Control.
Old Dec 18, 2017 | 07:45 PM
  #37
farmallmta's Avatar
farmallmta
If I don't mind the different look, will a 67-70 steering wheel interchange on a '75 column? No cruise, floor shifted manual, no tilt on the '75 column?
Old Dec 19, 2017 | 02:15 PM
  #38
NumberDummy
3 spoke 17" steering wheel using a horn button or ring:
1960/63 Falcon/Comet; 1961/66 F100/250 2WD; 1966 F100 4WD; 1966/73 Bronco (horn ring only); 1967/70 F100/250 2WD/4WD; 1969/70 F350.
Tilt wheel not available until 1978.
Old Dec 19, 2017 | 04:10 PM
  #39
farmallmta's Avatar
farmallmta
Thank you, but...
It's my understanding that parts interchange relates to the models/years that a specific part was actually used, as you've given above. My question is could a different part number fit and function as the original despite the non-original application? I'm curious because one of the earlier posters had indicated that a 67-70 steering wheel would fit onto the '75 F250 column. I suppose the question relates to the steering shaft diameter, spline count, length for mounting, and horn adaptability. Agreed, it would not be an original-style interchange, but could it physically function without modifications.
I appreciate you helping me with this, numberdummy.
Old Dec 19, 2017 | 07:51 PM
  #40
mofoco1's Avatar
mofoco1
Sorry thought this might help others.
So swapping out the entire columns is the best way I would assume if you want a specific style or year wheel, found this out trying to install the Leather wrapped Ford Sport wheel into the 75 SuperCab. One question as I don't have them here right now, but is the tilt auto column the same on the 4x4 as the 2x4?
GN1220
Sep 9, 2020 11:04 PM
fordiesel69
2004 - 2008 F150
Nov 16, 2017 08:40 AM
eagleye
WTB - Parts & other
Feb 27, 2017 06:35 PM
Your41Plague12
WTB - Parts & other
13
Dec 16, 2016 02:38 PM
geearturi
Aerostar
Apr 27, 2016 04:20 PM
